General Audi customization channels (Solution)
Michael II
Post08-01-2003, 12:21    Subject: General Audi customization channels Quote
Important: Adjustments should only be made if you have the necessary basic knowledge.
Audi, models from the year 2001 onwards, instrument cluster, channel 18.
Structure: XXXXX (five-digit code)
5. Location: Auxiliary heater.
Value 0: No auxiliary heating.
Value 1: Auxiliary heater installed.
Value 2: Auxiliary heating active with terminal 15.
Audi, models from the year 2002 onwards, instrument cluster, channel 19.
1. Subject: Behavior of instrument lighting.
Value 0: The pointers and scales are illuminated when the headlights are turned on.
Value 1: The indicators illuminate when the ignition is turned on, and the scales illuminate when the headlights are turned on.
Value 2: The scales are illuminated when the ignition is turned on, and the needles are illuminated when the headlights are turned on.
Value 3: The pointers and scales are illuminated when the ignition is switched on.
4. Location: Outdoor temperature display.
Value 0: off.
Value 1: on.
5. Location: Radio clock (if installed).
Value 0: off.
Value 1: on.
See also search for "ECU adaptation" or "adaptation channels."
Tschüss
Michael II
Ratings - General Audi customization channels
No new posts General information about PD testing for troubleshooting ... Troubleshooting & Guides
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts FIS in the Audi Transmission, Chassis, Body & Interior
No new posts Audi A3 8P 1.9 TDI BLS: Parts & Info Diesel Engine Technology
No new posts Audi A6 3.0 TDI ASB: Specs & Info Diesel Engine Technology
