bernie123 Blaumann
05-09-2008, 14:22 Subject: Defective Comfort Electronics: Troubleshooting & Repair |
Hello forum,
After a short period of battery drain, the comfort electronics no longer function properly.
Power windows, fuel tank lock, and rear hatch lock are malfunctioning/not working correctly.
"At a free and independent workshop, the error memory was checked and the fuses were inspected: no errors found."
What else could be checked?
What is the exact procedure for losing weight?
best regards
Bernie.
A2 TDI, manufactured in October 2000, with 75 horsepower.
Translated on 12-08-2026, 2:33.
bastion Blaumann
05-09-2008, 15:17 Subject: Defective Comfort Electronics: Troubleshooting & Repair |
Let's leave the battery disconnected for a while longer. Maybe the control units just crashed.
A4 Avant 08/01 AWX 05/08-
Translated on 12-08-2026, 2:34.
Elvis
Joined: 09/05/2008 Posts: 1 Karma: +0 / -0 Location: Lamprechtshausen ( A ) 2003 Seat Toledo Free account, no CAN development support
05-09-2008, 15:26 Subject: Defective Comfort Electronics: Troubleshooting & Repair |
Hello, I had a similar problem with my Seat Alhambra. It turned out that the fuel tank lid motor was faulty and caused a short circuit.
Profile PM Email Garage |
bernie123 Blaumann
05-09-2008, 16:24 Subject: Defective Comfort Electronics: Troubleshooting & Repair |
Unfortunately, I had the window slightly open and then it got stuck.
Is there anything that can be salvaged by disconnecting it for a longer period of time?
How is disconnecting officially handled?
The "Freie Werkstattleute" (independent craftsmen) meant the following here:
When connecting or disconnecting, consider using a device that can smooth out voltage spikes.
Translated on 12-08-2026, 2:35.
06-09-2008, 7:13 Subject: Defective Comfort Electronics: Troubleshooting & Repair |
Do the window lifters not work at all anymore, or have they just forgotten how to reach their end positions?
The latter wouldn't be a problem; simply hold the button in both positions for a few more seconds until the window stops moving and reaches its fully open or closed position.
Translated on 12-08-2026, 2:36.
Profile PM WWW Garage |
bernie123 Blaumann
06-09-2008, 7:18 Subject: Defective Comfort Electronics: Troubleshooting & Repair |
...The power windows, tailgate, and fuel filler cap are no longer working at all.
06-09-2008, 7:22 Subject: Defective Comfort Electronics: Troubleshooting & Repair |
Have you thought about the fuses?
Translated on 12-08-2026, 2:37.
06-09-2008, 7:23 Subject: Defective Comfort Electronics: Troubleshooting & Repair |
Quote: | | What is the exact procedure for losing weight? |
Unscrew the mass cable from the battery and put it aside.
bernie123 Blaumann
06-09-2008, 7:56 Subject: Defective Comfort Electronics: Troubleshooting & Repair |
Fuses in the interior and ground fault areas have been checked - OK.
As mentioned above, when connecting a mass, currents can flow that may lead to unhealthy voltage spikes – these would need to be discharged (quote from a local workshop).
Translated on 12-08-2026, 2:38.
