AGR errors
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post10-08-2009, 16:36    Subject: AGR errors Quote
Leon 1M, ARL engine, manufactured in May 2004.
Everything is as original as possible.
Check engine light is on, and this is the error code.
Address 01: Engine
Control unit part number: 038 906 019 KG.
Component and/or version: 1.9L R4 EDC 0400SG 5342.
Encoding: 00002
19586 - Exhaust gas recirculation system: Limit exceeded.
P3130 - 35-10 - - - Sporadically.
Readiness: 1 1 0 0 0
I suspect either a weasel bite or a faulty AGR valve.
Okay, so my question is: since I'm on the road and can't fix the problem right away,
Is it okay if I keep driving with this error for a while?
Does the MSG modify any values due to the error?
During operation, I didn't notice anything unusual.
reflexsilber met.
Post10-08-2009, 17:47    Subject: AGR errors Quote
Nana, someone has been messing with the adjustment channels icon_smile.gif.
If the dataset is original and the reason for the "playing" (likely referring to unusual behavior or noise) is a blockage in the EGR pipe, then the cause of the error has likely been identified.
If the dataset is from me, please set the adaptation channels back to the default (32768)); any further changes would be unnecessary and counterproductive.
Nothing major is likely to happen in the short term. In the long term, a stuck VTG (variable turbine geometry) is possible due to excessive soot/overheating caused by a mechanical defect in the EGR (exhaust gas recirculation) valve. In the latter case, prolonged full-throttle operation should obviously be avoided.
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts G28 Error: Find the Mistake! Diesel Engine Technology
No new posts ABS error On-Board Diagnostics (OBD)
No new posts WFS Errors: Troubleshooting and Solutions Diesel Engine Technology
No new posts 3C0-937-049-30-H Error: Troubleshooting Guide On-Board Diagnostics (OBD)
