Audi A4: Electronic Problems & Solutions
tommi
Post07-09-2008, 8:09    Subject: Audi A4: Electronic Problems & Solutions Quote
Good morning!
I'm having a problem with an Audi A4 3.0 TDI Quattro Tiptronic Avant, manufactured in 2005.
MKB:BKN GKB: CGX
The car runs normally when cold, and everything functions as it should. However, after driving for 10-20 kilometers, the...
The gear indicator in the instrument cluster switches to manual Tiptronic mode, and it downshifts all the way to 1st gear! You can then shift up, but it won't...
It was immediately switched back on. The selector lever remained in the "D" position the entire time.
The transmission's fault memory contains the following error!
Switch for Tiptronic (F189) down: Short circuit to ground.
The following items have already been exchanged and checked!
2 new circuit boards in the selector lever.
Mechatronics system complete with control unit and wiring harness, installed in the transmission!!
Fahrzeug wurde auf Wassereinbruch geprüft. Everything's fine!
Who can help with this problem?!
Translated on 09-10-2026, 10:21.
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electronics Failure Causes Train to Stop Diesel Engine Technology
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts Audi A6 3.0 TDI ASB: Specs & Info Diesel Engine Technology
No new posts 2L TDI 170 HP Audi A4 B7: Specs & Info Diesel Engine Technology
