T5 Tire Test: Best Tires Reviewed
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post30-09-2008, 21:03    Subject: T5 Tire Test: Best Tires Reviewed Quote
Bei der Beschaffung von M&S 235/55R17 für den T5 habe ich leider keine Tests/ Erfahrungen im Net gefunden. Not even summer:
The Michelin M&S tires were used in the front for one winter, with a maximum of 10,000 km driven, and performed well on slick surfaces.
Does anyone have any experience with that?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 02-08-2026, 22:23.
Karma: +1099 / -0   Thank you, like it!
Post30-09-2008, 22:48    Subject: T5 Tire Test: Best Tires Reviewed Quote
We have Goodyear Vector tires in size 215/65 R16 with the M&S marking as all-season tires on our company vans (T5 long wheelbase). With annual axle-by-axle replacement, they have lasted for 2 years and 50-65,000 km. The tread depth is still 5-6 mm on all of them. While all-season tires don't replace winter tires, they are sufficient here in the Berlin area and are probably also the best solution from a cost perspective.
Translated on 02-08-2026, 22:24.
Octavia_4x4
Post04-10-2008, 10:00    Subject: T5 Tire Test: Best Tires Reviewed Quote
So, on our company's T5 vans, we always used the standard 215 size tires in 16-inch rims for winter. The tires were Pirelli Citinet Winter – they were great in terms of grip, but after only 15,000 kilometers, half of the tread was gone.
and that's with the small TDI engine producing 131 horsepower and primarily used for city driving.
Translated on 02-08-2026, 22:25.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post19-10-2008, 11:35    Subject: T5 Tire Test: Best Tires Reviewed Quote
No, if the tires are size 235 on the front, they must also be size 235 on the rear. I've now purchased two more Yokohama W Drive tires and have two in reserve, in case the Michelins wear out or aren't suitable for snowy conditions.
Emergency doctor Zubinger T5. It should have a more distinctive profile.
I also had the Pirelli Citinet in size 215/65R16C for the last two winters. They lasted well and were quiet on the road, but they are no longer easily available. There is now a successor model, but it has two solid shoulder blocks, which I felt didn't offer enough grip for winter conditions, just like the Michelin Agilis 51.
Translated on 02-08-2026, 22:26.
Octavia_4x4
Post19-10-2008, 18:00    Subject: T5 Tire Test: Best Tires Reviewed Quote
I'm curious to see what the replacements are like. Our T4 Syncro now has them on the front, but still has the older Citinets on the back.
"And it will be driven off-road, so I'm curious to see if we'll need to use a tractor to pull vehicles out of the mud more often this winter."
Translated on 02-08-2026, 22:27.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post19-10-2008, 18:57    Subject: T5 Tire Test: Best Tires Reviewed Quote
Not yet this year, but next winter.
Translated on 02-08-2026, 22:28.
Octavia_4x4
Post19-10-2008, 21:31    Subject: T5 Tire Test: Best Tires Reviewed Quote
Okay, then I'm relieved; it seems my father did get the "old" Cinetone devices after all.
because the goods were acceptable, we only needed a tractor twice during that winter icon_confused.gif.
