Defective Comfort Electronics: Troubleshooting & Repair
bernie123
Post05-09-2008, 15:22    Subject: Defective Comfort Electronics: Troubleshooting & Repair Quote
Hello forum,
After a short period of battery drain, the comfort electronics no longer function properly.
Power windows, fuel tank lock, and rear hatch lock are malfunctioning/not working correctly.
"At a free and independent workshop, the error memory was checked and the fuses were inspected: no errors found."
What else could be checked?
What is the exact procedure for losing weight?
best regards
Bernie.
A2 TDI, manufactured in October 2000, with 75 horsepower.
Translated on 12-08-2026, 3:33.
bastion
Karma: +6 / -1   Thank you, like it!
Post05-09-2008, 16:17    Subject: Defective Comfort Electronics: Troubleshooting & Repair Quote
Let's leave the battery disconnected for a while longer. Maybe the control units just crashed.
A4 Avant 08/01 AWX 05/08-
Translated on 12-08-2026, 3:34.
Elvis
2003 Seat Toledo
Post05-09-2008, 16:26    Subject: Defective Comfort Electronics: Troubleshooting & Repair Quote
Hello, I had a similar problem with my Seat Alhambra. It turned out that the fuel tank lid motor was faulty and caused a short circuit.
bernie123
Post05-09-2008, 17:24    Subject: Defective Comfort Electronics: Troubleshooting & Repair Quote
Unfortunately, I had the window slightly open and then it got stuck.
Is there anything that can be salvaged by disconnecting it for a longer period of time?
How is disconnecting officially handled?
The "Freie Werkstattleute" (independent craftsmen) meant the following here:
When connecting or disconnecting, consider using a device that can smooth out voltage spikes.
Translated on 12-08-2026, 3:35.
Post06-09-2008, 8:13    Subject: Defective Comfort Electronics: Troubleshooting & Repair Quote
Do the window lifters not work at all anymore, or have they just forgotten how to reach their end positions?
The latter wouldn't be a problem; simply hold the button in both positions for a few more seconds until the window stops moving and reaches its fully open or closed position.
Translated on 12-08-2026, 3:36.
bernie123
Post06-09-2008, 8:18    Subject: Defective Comfort Electronics: Troubleshooting & Repair Quote
...The power windows, tailgate, and fuel filler cap are no longer working at all.
Post06-09-2008, 8:22    Subject: Defective Comfort Electronics: Troubleshooting & Repair Quote
Have you thought about the fuses?
Translated on 12-08-2026, 3:37.
Post06-09-2008, 8:23    Subject: Defective Comfort Electronics: Troubleshooting & Repair Quote
bernie123
Post06-09-2008, 8:56    Subject: Defective Comfort Electronics: Troubleshooting & Repair Quote
Fuses in the interior and ground fault areas have been checked - OK.
As mentioned above, when connecting a mass, currents can flow that may lead to unhealthy voltage spikes – these would need to be discharged (quote from a local workshop).
Translated on 12-08-2026, 3:38.
No new posts Doku A6 4B, Einparkhilfe defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AKN: Partial Power Outage Affects Service Diesel Engine Technology
No new posts Dashboard Lights Not Working? Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts LLC Effects: Some Mysteries Unveiled? Diesel Engine Technology
No new posts Golf 4 Front Axle: Partial Replacement Guide Transmission, Chassis, Body & Interior
