Outside temperature sensor
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Schneemann
Avatar-Schneemann
Post21-11-2009, 22:01    Subject: Outside temperature sensor Quote
Hello and good evening.
"My external temperature sensor from the Climatronic system has been showing readings that are consistently 6-10 degrees too low lately, so I'd like to replace it, or if there's a nearby connector, clean it. Basically, I just want to know where to find this thing."
Does anyone know the specifications? Because if it's a PT100 sensor, I could practically replace it for free.
Gruß Schneemann
Golf Plus Highline Bj. 09/2010 CFHC. eFH, eSP, Climatronic, PDC, AHK, ABS, ESP, GRA, MFA, LMAA, FDH, BSE, Brenderup Kippi 200 und ne Traumfrau auf dem Beifahrersitz.
Translated on 14-07-2026, 1:45.
Devilseye503
Post21-11-2009, 22:26    Subject: Outside temperature sensor Quote
...I don't know what characteristic this part has... but one thing I know for sure - it definitely isn't a component designed for automation technology, like a PT100 characteristic icon_wink.gif.
Oh yeah, and that part usually sits somewhere on the left side of your bumper...and behind it, there's also a nice little connector.
Translated on 14-07-2026, 1:46.
Schneemann
Avatar-Schneemann
Post21-11-2009, 22:32    Subject: Outside temperature sensor Quote
Well, even on a classic VW Beetle, there are many parts that I can replace with parts from my own workshop or use to repair it. This applies to both electrical/electronic and mechanical components. So far, it has always worked very well.
I would still like to hear a second opinion...
But thank you, I don't think I would have guessed that.
Gruß Schneemann
Translated on 14-07-2026, 1:47.
Post22-11-2009, 12:15    Subject: Outside temperature sensor Quote
Okay, the temperature sensor on the bumper is for the MFA (Multi-Function Display). Unfortunately, in our older VWs, there are two temperature sensors located there if you have air conditioning installed. The sensor you're looking for should be somewhere near the interior air intake. I'm quite sure of that.
Translated on 14-07-2026, 1:48.
Schneemann
Avatar-Schneemann
Post22-11-2009, 12:19    Subject: Outside temperature sensor Quote
Good morning, everyone.
I found the sensor behind the bumper. I just haven't felt like tinkering with it yet.
My MFA (Multifunction Display) doesn't have a temperature display because it's integrated into the Climatronic system. Does anyone really know anything about the sensor characteristics? Sorry if I'm bothering you icon_redface.gif.
Gruß Schneemann
Translated on 14-07-2026, 1:49.
Devilseye503
Post22-11-2009, 19:23    Subject: Outside temperature sensor Quote
@matthias... well, he wanted the outside temperature. The climate control system measures the interior temperature. In almost all German vehicles, we let the air pass through a small fan and flow past the sensor; in other words, it's located directly within the climate control unit, the center console, or wherever icon_wink.gif.
...aunt edit:
Matthias is referring to the second temperature sensor located in the fresh air intake duct. The two outdoor temperature sensors switch their functions; if one is defective, the other takes over. However, the actual outdoor temperature sensor is the one located in the bumper.
Translated on 14-07-2026, 1:50.
Post22-11-2009, 20:27    Subject: Outside temperature sensor Quote
icon_smile.gif ...that's what I meant.
Translated on 14-07-2026, 1:51.
No new posts The outside temperature sensor is showing a reading that ... Transmission, Chassis, Body & Interior
