If there is a fault, the engine will noticeably have less power. The error doesn't always occur, but as far as I can tell, it only happens when I start the engine immediately, i.e., directly in gear 2.
Sure, here's the translation:
"Addendum:"
I had a software update installed on my car today by a friendly mechanic.
Now, this error is not appearing on the MSG (Main System Gateway), but on the AI (Artificial Intelligence) control unit.
Address 17: Combination Instrument
Label file: RKS\1K0-920-xxx-17.lbl
Part number SW: 1K0 920 863 B, Hardware number: 1K0 920 863 B.
Component: COMBINATION INSTRUMENT VN4 8212
Revision: V0007000 Serial Number: VWZBZ0F0518112
Encoding: 0007103
Operating number: WSC 01287 785 00200
"1 error found:"
01314 - Engine Control Unit.
004 - No signal/communication - Sporadically.
Environmental conditions:
Error status: 00100100
Error priority: 5
Error frequency: 1
Lost Count: 132
Mileage: 25501 km
Time: 0
Date: 2000.00.00
Time: 15:11:54
Try connecting a different engine control unit (ECU) to see if it resolves the issue.
Best regards.
Olli
I'm not sure if that's a good idea. If I do that, I'll not only have one error, but 50 other errors in the memory, and there's a chance the engine won't even start. Furthermore, I also don't have a way to obtain a suitable MSG (message) for testing.
