Document A4 8D, production date up to 10/1999, dents on the D-pillar (Solution)
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post08-01-2003, 15:53    Subject: Document A4 8D, production date up to 10/1999, dents on the D-pillar Quote
Dents or depressions on the outer surface of the D-pillar.
Cause:
Incorrectly set mixing parameters for the insulation foam in the D-pillar result in shrinkage of the insulation foam. The insulation foam, which is attached to the outer skin of the D-pillar, is integrated into the structure.
Solution:
Preheat the area to be bonded using a hot air gun (approximately 450°C outlet temperature) mounted on a D-pillar, keeping a distance of approximately 5 cm for 2-3 minutes. The indentations will naturally disappear due to the effect of heat.
Sure, here's the translation:
"Note:"
Choose a temperature that is not too high, as this could cause discoloration in the topcoat.
TschĂŒss
Michael II
Ratings - Document A4 8D, production date up to 10/1999, dents on the D-pillar
No new posts Lupo Dents: 6X1 MJ 2002 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L bis 06/2000, KnackgerÀusche B-SÀule Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L MJ 1999: Rattling/Humming Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wasser in A-SĂ€ule Audi100 C4 Transmission, Chassis, Body & Interior
No new posts How do you loosen the hinge screws on the A-pillar? Transmission, Chassis, Body & Interior
No new posts Golf 4 leaking at the A-pillar (4-door) Transmission, Chassis, Body & Interior
No new posts What is the purpose of an ABE (General Operating Permit) ... Transmission, Chassis, Body & Interior
