derkater
Joined: 07/04/2008 Posts: 25 Karma: +0 / -0 Location: Berlin
28-09-2008, 10:13 Subject: Can you read the oil pressure? |
My previous search in the repair manual was unsuccessful. Therefore, my question is whether it is possible to read the oil pressure (via the measurement block).
Thank you and greetings.
Stephan.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
28-09-2008, 10:22 Subject: Can you read the oil pressure? |
Depending on the vehicle and the installed control unit, this can be done through the instrument cluster.
Unfortunately, it doesn't display the oil pressure as an 'x bar' value, but only indicates whether it's 'sufficient' or not. Take a look at what type of oil pressure switch is installed and at what pressures it switches.
Profile PM WWW Garage |
derkater
28-09-2008, 10:49 Subject: Can you read the oil pressure? |
Okay, then I guess I should take a look at the accessories. It's strange that there are no specific values available for the gasoline version.
Best regards, Stephan.
