KPerformance: Troubleshooting and Solutions
Tobi12345
Post29-09-2008, 17:34    Subject: KPerformance: Troubleshooting and Solutions Quote
A friendly hello to everyone.
"Recently, I've been having a problem where KPerformance won't run. I can open it, but when I press the button to start the measurement, I always get a message saying that the program is no longer working correctly and is therefore being stopped. Also, the VCDS feature "Acceleration" (which also measures acceleration) is not working either."
I've already tried disabling the firewall, but it didn't help.
I'm using a laptop with Vista, and I've already performed measurements using KPerformance, but with an older version.
VAG-COM.
Have you experienced anything similar? Do you have any solutions or suggestions? Or does anyone have a tip as to what might be causing this?
Thank you all, and have a pleasant evening.
Best, Tobi.
A6 Avant 3,0TDI Tiptronic Bj. 02/2008
Translated on 17-09-2026, 5:19.
Post29-09-2008, 19:26    Subject: KPerformance: Troubleshooting and Solutions Quote
What version of VCDS is being used, and what is its data version?
What exactly are the error messages for both actions? Screenshots would be best.
Translated on 17-09-2026, 5:20.
Tobi12345
Post29-09-2008, 20:14    Subject: KPerformance: Troubleshooting and Solutions Quote
Hi Rainer, and thanks for taking on this matter.
Here are the screenshots, as promised!
Okay, before I forget, regarding the acceleration feature in VCDS, it shows...
Please provide a Screenshot of the image that appears immediately after pressing the start button.
Best, Tobi.
Fehlermeldung KPerformance.doc
 File name:  Fehlermeldung KPerformance.doc
 File size:  642.5 KB
 Downloaded:  519 times
Datenstand VCDS.doc
 File name:  Datenstand VCDS.doc
 File size:  722 KB
 Downloaded:  532 times
Translated on 17-09-2026, 5:21.
Tobi12345
Post29-09-2008, 20:15    Subject: KPerformance: Troubleshooting and Solutions Quote
Oops, I think my finger hit "send" too early.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post30-09-2008, 16:07    Subject: KPerformance: Troubleshooting and Solutions Quote
Then I'm not alone.
I'm experiencing the exact same problem. My laptop is a Fujitsu Siemens Amilo with Vista. I'm using the latest USB version of VCDS from Rainer. I've already reinstalled Vista without any security software (unfortunately, I couldn't install XP), and it still doesn't work. I'll try running it in safe mode on my way home today.
Passat Variant BGW 2005
Translated on 17-09-2026, 5:22.
Steffen W
Post01-10-2008, 18:02    Subject: KPerformance: Troubleshooting and Solutions Quote
It doesn't work even in safe mode. It's probably a problem with Vista.
Steffen W
Post04-10-2008, 7:04    Subject: KPerformance: Troubleshooting and Solutions Quote
For Rainer, for potential fixes in later versions:
In Safe Mode on Vista Home Premium, when you click on...,
"Press the 'start' button." "API server not found" or similar.
In safe mode with network drivers, as well as in normal mode, the error message "Application failed to start" appears, along with an address indicating a protection violation.
It starts without any problems on the stationary computer in the garage, which is running Windows XP. However, that computer is stationary.
The XP installation failed on the laptop. I thought it would be the easiest thing to do. When starting from the XP CD, the setup doesn't find any installed hard drive. It might be worth trying to use Partition Magic and wiping Vista first. However, if it still doesn't work, and I don't know if it will, I won't have an operating system. I didn't get a CD for Vista. I only have a recovery tool for backing up and restoring HD images, but that will be gone if I format the drive.
Before I jump into the deep end and just try it, I'll test the network settings in Vista one more time. I'll get back to you.
Translated on 17-09-2026, 5:24.
Post04-10-2008, 10:08    Subject: KPerformance: Troubleshooting and Solutions Quote
Please unpack this KPerformance.exe file and place it in the plugins directory.
If it crashes again, please take a Screenshot of the Windows error message, including the addresses.
The "normal" Vista mode is fine.
The error is definitely in the program; I'm just not entirely sure yet where the problem lies.
KPerformance.rar
 File name:  KPerformance.rar
 File size:  586.45 KB
 Downloaded:  587 times
Translated on 17-09-2026, 5:25.
Tobi12345
Post04-10-2008, 12:14    Subject: KPerformance: Troubleshooting and Solutions Quote
Hi Rainer!
Okay, I'm going to get started on this now. Should I delete anything from the "Plugins" folder beforehand, or does VCDS automatically copy the newly added files?
Best, Tobi.
Translated on 17-09-2026, 5:26.
Post04-10-2008, 13:11    Subject: KPerformance: Troubleshooting and Solutions Quote
Well, the program name is the same, so the .exe file will overwrite the existing one. Since the old .exe file doesn't work for you anyway, you don't need to back anything up. icon_smile.gif
Translated on 17-09-2026, 5:27.
Tobi12345
Post04-10-2008, 15:35    Subject: KPerformance: Troubleshooting and Solutions Quote
Thank you for the support. So, was the problem related to Vista? Will I likely experience something similar with the VCDS feature acceleration?
But that doesn't really matter, because Ross-Tech will probably fix the bug in the next software update.
It's important to me that your plugin is working again.
Thank you very much, and I hope you have a nice weekend.
Best, Tobi.
Steffen W
Post04-10-2008, 16:39    Subject: KPerformance: Troubleshooting and Solutions Quote
I confirm: Mine is working again too!
Everything is fine, and thank you again.
Translated on 17-09-2026, 5:28.
Post04-10-2008, 17:28    Subject: KPerformance: Troubleshooting and Solutions Quote
Great, thanks for the feedback! I'll go ahead and create a version without debug information.
Vista exhibited a slightly different behavior in its messaging, which revealed a bug in the display class.
Translated on 17-09-2026, 5:29.
No new posts T5 Bremsflüssigkeits-MIL ohne Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A6 4B, Türschloß ohne Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, Aussenspiegelglasheizung ohne Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia TDI: Power Steering Failure - Help! On-Board Diagnostics (OBD)
No new posts Zylinderkopfdichtung defekt - bitte um Hilfe Diesel Engine Technology
No new posts High-pressure pump screw sheared off, need help Diesel Engine Technology
No new posts Friendly Confusion: Advice and Help Needed Diesel Engine Technology
