Coolant Leak: A4 8D Doku, Up to Week 45/1998 (Solution)
Michael II
Post09-01-2003, 11:57    Subject: Coolant Leak: A4 8D Doku, Up to Week 45/1998 Quote
Coolant leak at the coolant reservoir.
Cause:
Hose connection between the bleed hose and the expansion tank is not properly connected.
The connector housing for the coolant sensor on the expansion tank is leaking.
Due to a manufacturing defect, the mesh inside the coolant hose is loose. As a result, the coolant leaks out through the vent hose connection to the expansion tank due to capillary action.
Solution:
Replace the hose clamp.
Disconnect the coolant level sensor connector. If there are traces of coolant visible in the connector housing, replace the expansion tank.
If coolant leaks through the fabric of the coolant hose at the connection to the expansion tank, the coolant hose must be replaced.
"Note:"
Coolant traces on the seam of the expansion tank can have the following causes:
- Leak in the hose connection on the vent hose.
- Overfilling of the cooling system, causing coolant to be expelled through the filler cap of the expansion tank.
- The pressure relief valve in the lid is not maintaining the required pressure.
Tschüss
Michael II
Translated on 24-10-2026, 17:53.
Ratings - Coolant Leak: A4 8D Doku, Up to Week 45/1998
Average rating: 4.00 - worst rating: 4 - best rating: 4 - number of ratings: 1 - View ratings
No new posts Document: Coolant Loss, AGP, AGR, AHF, ALH, AQM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coolant leak in hoses Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Engine Performance Data, MJ 1998 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Engine Performance Issues: MJ 1998 Documentation Diesel Engine Technology
No new posts Coolant Leak Audi A4 AFN: Causes & Fixes Transmission, Chassis, Body & Interior
No new posts Coolant Leak Golf 5 2.0 BKD Diesel Engine Technology
No new posts Water Leak Audi A3 8L (1998) Fix Transmission, Chassis, Body & Interior
