1Z with Vmax <140km/h
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Upload
Post15-10-2008, 7:26    Subject: 1Z with Vmax <140km/h Quote
Attached are the logs from the Passat by Colt-Seavers.
Thread: /viewtopic.php?p=136766
Problem: The vehicle seems to have only about half its maximum power, the Vmax is below 140km/h, the fault memory is clear, (only 17978 - Engine control unit locked, P1570 - 35-10 - - - Sporadically)
The timing belt had very little tension.
arne_LOG-01-001-008-011.CSV
 und die originale CSV Datei
 File name:  arne_LOG-01-001-008-011.CSV
 File size:  10.7 KB
 Downloaded:  819 times
Arne.xls
 Einmal als XLS mit Diagrammen
 File name:  Arne.xls
 File size:  40.5 KB
 Downloaded:  666 times
No new posts Acceleration Ends Before Max Speed General Tips
No new posts Audi A6 (4B) vibrates from 140 km/h Transmission, Chassis, Body & Interior
No new posts Vibrations in the steering wheel at approximately 140 km/h Transmission, Chassis, Body & Interior
No new posts Speed Limit Problem: Troubleshooting & Solutions Diesel Engine Technology
No new posts Low Max Speed, LOG-MWB 3-8-11 Upload
