dcjf Guest
10-10-2005, 23:41 Subject: Audi AEL 4A0907401P Login Error? |
Hello everyone,
I'm unable to access the engine control unit using VAG-COM. The vehicle is a 1997 model.
'The standard login code 12233 doesn't work; the connection drops, and I have to turn the ignition off and on again before the connection is restored. There's no error message indicating that I've entered an incorrect login code. Yes, I have a VAG-COM license and a really great interface adapter for it. Otherwise, the communication works without any problems.'
Thank you in advance for any response!
Translated on 11-09-2026, 22:29.
Ross-Tech-Support Profi-Schrauber
11-10-2005, 0:18 Subject: Audi AEL 4A0907401P Login Error? |
The login mentioned only applies to 4-cylinder diesel engines; your 5-cylinder engine requires a different one.
Translated on 11-09-2026, 22:30.
Trecker Treiber Guest
11-10-2005, 8:05 Subject: Audi AEL 4A0907401P Login Error? |
@Besswerwisser: The AEL is a 5-cylinder engine.
But the login code is already correct. However, I don't have a good solution for your problem right now.
11-10-2005, 9:51 Subject: Audi AEL 4A0907401P Login Error? |
Trecker Treiber wrote: | | @Besswerwisser: The AEL is actually a 5-cylinder engine | .
Typo... *fixed*
Trecker Treiber wrote: | | But the login code is already correct. |
How do you come up with...
Translated on 11-09-2026, 22:31.
Rudi Guest
11-10-2005, 9:58 Subject: Audi AEL 4A0907401P Login Error? |
Try 26242.
Rudi
Translated on 11-09-2026, 22:32.
11-10-2005, 10:21 Subject: Audi AEL 4A0907401P Login Error? |
@Besswerwisser
I'm bringing this up because it's mentioned in the forum, and it works for me. Since the specifications of the AAT and AEL are identical, except for the configured parameters, it should work.
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
11-10-2005, 14:56 Subject: Audi AEL 4A0907401P Login Error? |
Hi Rudi,
I had 26262 here? Are you sure, or did I mistype?
Translated on 11-09-2026, 22:34.
Profile PM WWW Garage |
11-10-2005, 14:57 Subject: Audi AEL 4A0907401P Login Error? |
Rainer K. wrote: | | ...I had 26262 here? Are you sure, i.e., did I mistype something? |
I have both of them here... but they vary quite a bit depending on the specific model.
11-10-2005, 15:01 Subject: Audi AEL 4A0907401P Login Error? |
@Know-it-all: Thank you.
"This is a pain... trying things out like this probably isn't the solution. Does anyone have an idea if we can at least assign it to the same ICD codes?"
Translated on 11-09-2026, 22:35.
Rudi Guest
11-10-2005, 21:06 Subject: Audi AEL 4A0907401P Login Error? |
Hello Rainer,
Do not misspell  .
26281, 26282, 26252, and 26232 are also some of them...
Rudi
11-10-2005, 23:48 Subject: Audi AEL 4A0907401P Login Error? |
Rainer K. wrote: | | Does anyone have an idea if it can at least be assigned to the same MKBs? |
Logins are usually selected randomly. If the MKB (engine code) is correct, the login will also be correct. However, this does not apply in cases where the engine control unit or fuel injection system generation changes. While trial and error is not the ideal solution, I personally do not believe that a publicly accessible list of logins would be useful.
80% of the logins/security accesses have no impact on the normal diagnostic operation; they are used for flashing or other access methods that are, in principle, irrelevant. Others are downright dangerous, while still others are only truly useful at the end of the process, such as the readiness acceleration.
Translated on 11-09-2026, 22:36.
dcjf Guest
15-10-2005, 14:48 Subject: Audi AEL 4A0907401P Login Error? |
Hello Rudi,
Hello Rainer,
Do not misspell  .
Best regards, Rudi
What happens on your end when you enter the wrong login? Does the connection drop, or do you get a message like 'Incorrect login'?
Translated on 11-09-2026, 22:38.
Rudi Guest
15-10-2005, 17:24 Subject: Audi AEL 4A0907401P Login Error? |
Anything is possible (depending on the tool and control unit).
If none of the login attempts are successful, I would suggest stopping before trying any more.
Try to always turn off the traction control system.
Rudi
dakoal Blaumann
Joined: 05/31/2005 Posts: 66 Karma: +5 / -0 Location: Hausleiten
07-08-2006, 6:21 Subject: Audi AEL 4A0907401P Login Error? |
Good morning.
I want to reduce the AGR (Abgasrückführung) rate in my ECO-tuned AEL engine by increasing the target air mass. (From a technical article). Unfortunately, none of the 5 login attempts worked. I would also appreciate a private message.
Rainer should know my current data status (based on the tuning process).
I'll ask him about it today.
Sure, here's the translation:
"Best regards," or "Sincerely,".
dakoal ____________________________________
Audi A6 Avant (C4) 2,5TDIi MKB:AEL, BJ 1995 @ 220tkm
VW Golf III 1,9D MKB:1Y, BJ 1995 @ 182tkm R.I.P. (Rest in Poland)
Translated on 11-09-2026, 22:39.
Profile PM Email |
Nebelwerfer_TDI Guest
07-08-2006, 9:34 Subject: Audi AEL 4A0907401P Login Error? |
I would be surprised if Rainer didn't completely disable the AGR (Exhaust Gas Recirculation). Otherwise, you can also physically block the AGR on your car with a piece of metal, as it's not monitored.
Translated on 11-09-2026, 22:40.
