A4 Doku: Engine Control Not Connecting to WFS. (Solution)
Michael II
Post09-01-2003, 12:12    Subject: A4 Doku: Engine Control Not Connecting to WFS. Quote
The engine control unit cannot be adapted to the immobilizer system.
Cause:
For the 2000 model year, a new generation of circuit breaker panels was introduced (featuring a new lighting concept, extended maintenance intervals, etc.).
This circuit board module is already internally prepared for the third generation of immobilizer systems, but that functionality is not currently activated.
Solution:
To adapt a motorcycle engine control unit (ECU) to the immobilizer system, a login procedure must first be performed in the dashboard module. This involves entering the immobilizer security code. Only after this can the engine control unit be adapted (diagnostic function 10, channel 00).
Tschüss
Michael II
Translated on 30-09-2026, 12:06.
Ratings - A4 Doku: Engine Control Not Connecting to WFS.
No new posts Doku Lupo 6X1 MJ 2002, Engine will not start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentary: Air vent nozzle cannot be closed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Door Seal Repair: 2000 Model Drip Cover Issue Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts V6 TDI: Engine won't start after camshaft replacement? Diesel Engine Technology
No new posts AC won't turn on? Troubleshooting guide Transmission, Chassis, Body & Interior
No new posts Save Error: New Value Not Saving On-Board Diagnostics (OBD)
No new posts The steering angle at the BRS motor does not change Diesel Engine Technology
