Based on this information, I can only see that cylinder 3 consistently has a slightly higher correction value, but it's still within the tolerance range (+/- 2.8 mg, if I recall correctly). It's impossible to determine whether this is due to poor compression or partially clogged injectors.
MWB 18 and 23 are normal.
It's important to always log the PDE-Check-MWB data along with MWB1, so you can see the current engine speed and (average) injection quantity. The fact that only 2 MWB (besides 1) are available is a system limitation.
Translated on 09-09-2026, 22:55.
