ATD Performance Issues: Troubleshooting Guide
Fabia.S
Post23-12-2008, 17:53    Subject: ATD Performance Issues: Troubleshooting Guide Quote
"In my Fabia with the ATD engine, I've noticed a decrease in performance recently."
However, this also results in increased fuel consumption, even when driving at the same speed and with a similar style.
Even with constant highway driving at 120 km/h, it's difficult to achieve an average fuel consumption of less than 5.3 liters.
The diagnostic tests I ran show all the usual values within the normal range. From the mass airflow rate to the boost pressure, the readings seem to be okay. However, in the lower RPM range, up to about 1400 RPM, the actual boost pressure is significantly below the target value, and that's also why the acceleration feels sluggish at those speeds.
I would like to include the logs I created as attachments, but I don't see a way to upload the .xls file here.
Perhaps someone could take a look at the logs and then send them over.
The car is somehow only making slow progress. The fuel consumption at 100 km/h is easily around 5 liters.
When accelerating, the turbocharger's effect is barely noticeable, and it doesn't really kick in until above 2000 RPM.
The engine starts without any problems, even when cold, runs smoothly, and otherwise shows no unusual signs.
One thing I've noticed is that either I'm still experiencing some hearing issues, or the engine seems to be running "quieter" than I remember it being (the PD engine). Also, I can no longer hear that familiar slight whistling sound of the turbocharger when you give it full throttle in the lower RPM range.
During a full-throttle run, the car took just under 55 seconds to accelerate from 100 to 160 km/h, and approximately 31 seconds to go from 160 to 180 km/h.
I can send you the logs if you like.
Bertil noch mals Dank für den Tipp mit den Dateien. Here is the link.
Okay, I'm ready. Please provide the German text you want me to translate into English.
Thank you for your responses.
Fabia 1.9 Combi, Bj. 2001,ATD Euro 3
Spritspartuning aus dem Shop,Schlechtwegefahrwerk, 285000 km
Translated on 18-08-2026, 5:28.
Post23-12-2008, 18:12    Subject: ATD Performance Issues: Troubleshooting Guide Quote
That's good...
There's a sub-forum called "Upload" where you can upload the logs and then link to them here in this thread.
Okay, I'm ready. Please provide the German text you want me to translate into English. Just paste it here, and I will give you the translation.
Translated on 18-08-2026, 5:31.
Fabia.S
Post24-12-2008, 11:36    Subject: ATD Performance Issues: Troubleshooting Guide Quote
Thanks, Bertil, for the tip about uploading; it worked quite well.
Okay, I think anything above five liters per 100 kilometers is simply too much fuel consumption. Since I've been driving the same route again recently, I have a good basis for comparison.
I hope I'm not already so used to the PS system that I'm just misinterpreting things. But it definitely consumes significantly more than usual.
Here's the link to the files again.
Thank you.
Translated on 18-08-2026, 5:33.
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diagrams of Torque/Power with VCDS/VAG-COM Technical Articles
No new posts AFN Engine Performance Data, MJ 1998 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ATD Performance Issues: Troubleshooting Files Upload
No new posts TDI 1Z: No Power? Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts No power with the TDI! LMM=OK! Diesel Engine Technology
No new posts No power after removing the EGR valve on an AFN TDI Diesel Engine Technology
