Golf 3 TD AAZ: Clicking Noise Under Load
segelflieger
Post01-05-2002, 22:46    Subject: Golf 3 TD AAZ: Clicking Noise Under Load Quote
My engine (AAZ) makes a clicking sound when I accelerate and under partial load. It's not very loud yet, but it's noticeable at lower speeds. It also seems to be getting louder with increasing mileage (or at least that's what I think). The engine has 176,000 km on it and was manufactured in June 1993.
What could be the cause? (I mean, it might be the valves, or something like that.) Does anything need to be done?
Perhaps someone could recommend a book or website where I can learn more about this. If anything needs to be done, I would prefer to do it myself, if possible and without requiring any specialized tools, for both cost-effectiveness and enjoyment.
Hello.
Gerald.
Translated on 01-08-2026, 8:54.
Stukov
Post03-05-2002, 10:01    Subject: Golf 3 TD AAZ: Clicking Noise Under Load Quote
'A clicking sound that seems to be coming from the engine compartment, specifically from the area around the transmission/engine. I'm very familiar with this noise; I've heard it in my AAZ for 50,000 km, and it hasn't changed. At some point, I just stopped noticing it. I'm also curious what it actually is, although I still suspect something related to the clutch cable.'
Translated on 01-08-2026, 8:56.
Martin L.
Post06-05-2002, 13:07    Subject: Golf 3 TD AAZ: Clicking Noise Under Load Quote
Here are the sounds my AAZ engine makes:
at 1800 and 3600 RPM:
'Grrr' - a loud, metallic vibration, coming from somewhere in the exhaust system.
A new inner tube solved the problem in 14 days. Has anyone else experienced this issue?
I hear it on almost every passing GIII AAZ!
-> straightforward / no problem.
sometimes:
klackern ähnlich wie ABS, nur niederfrequenter. Perhaps it will work.
'some pipe somewhere. Could that be what you described?'
It could be a noise.
-> straightforward / no problem / uncomplicated
What else is supposed to be there:
Incorrect crankshaft bolt. The 8.8 grade bolts loosen and vibrate.
dem Kurbelwellenstumpf. Nit gut. Sofort überprüfen. M'It's a size 12.8.'
Screw it in. The 8.8 series was a long-running product. You can see it from below.
Translated on 01-08-2026, 8:58.
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Document: Tapping Noises Below 1600 RPM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Screenshot unter Windows erstellen und posten General Tips
No new posts Physics Fun: A Treat for Physicists Diesel Engine Technology
No new posts Cold Start Diesel Engine: 101 PS Below 0°C Diesel Engine Technology
No new posts LL3 oil not for PD under MD 02? Diesel Engine Technology
No new posts MWB 13 Values Under Load: Key Insights On-Board Diagnostics (OBD)
