Audi A6: Engine Won't Start - Troubleshooting Guide
Go to page: 1, 2  Next
chli1976
Post23-11-2008, 20:42    Subject: Audi A6: Engine Won't Start - Troubleshooting Guide Quote
I'm having a problem with a friend's Audi A6 2.5 TDI AKE Quattro automatic transmission, manufactured in 2003.
When I received it, it wouldn't start. I managed to get it running with the help of starting fluid, but it has an uneven idle, no throttle response, and a lot of white smoke.
I suspected he had put the wrong fuel in because he told me he had filled it from a canister. He works for an oil company and got the diesel from there, but its color is milky, and I've had problems with that type of diesel before.
Okay, I drained the old diesel, filled it with new diesel, replaced the diesel filter, and flushed the lines with new diesel using a pressure test pump (MWB 35).
It started immediately, but the idle was uneven, and there was a lot of white smoke again. After about 20 minutes of idling, it seemed okay, but when I tried to accelerate, the engine wouldn't respond, and there was a lot of white smoke again.
I then checked the injection timing. When it's retarded (late), it's okay at 4° BTDC (before top dead center), but when it's advanced (early), I'm getting 0° instead of a minimum of 12° BTDC.
In the engine control unit's fault memory, there is...
00550 - Injection start control.
17-10 - Rule difference - Occasionally recorded.
The transmission control unit (TCU) and the anti-lock braking system (ABS) control unit have error codes stored in their memory.
18265 - Malfunction Indicator Light: Error message from the engine control unit.
P1857 - 35-00 - - has been stored, the ESP lamp is illuminated, and all three errors cannot be cleared.
If I turn off the ignition for a while and then start the engine, the ESP light goes out and the idle returns to normal. However, when I press the accelerator, the ESP light comes back on, and the engine doesn't respond to acceleration, and I also think I hear a different engine idling noise.
In the Motorsteuergerät (engine control unit) module 18/3, I once had a fault code where bit 00001000 indicated a problem with the injection timing adjustment.
The fuel pump in the tank delivers one liter of diesel within 20 to 30 seconds. I haven't measured the pressure because I don't know the target value.
The vacuum pump should normally draw fuel through the wing cells' pumps.
What do you think? Is the radial piston pump broken, or is it just a fuel shortage?
Sunday, November 23, 2008, 6:57:19 PM: 15740
VCDS version: DRV 805.1.
Data as of: 20081030.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag für einen Spaziergang."
Vehicle type: 4B - Audi A6 C5.
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
Vehicle Identification Number (VIN): WAUZZZ4B43N021077
Mileage: 139,410 km
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine Control Unit (ECU)
Label file: DRV\059-907-401-AKE.lbl
Part number: 4B2 907 401 J
Component: 2.5L/4VTEDC G000AG D09
Encoding: 01016
Operating number: WSC 02325.
WAUZZZ4B43N021077 AUZ7Z0B2169915
"One error found:"
17-10 - Rule difference - Intermittent/Sporadic.
Readiness: Not Available.
Address 02: Transmission. Label file: DRV\01V-927-156.lbl.
Part number: 4B0 927 156 ES
Part number: AG5 01V 2.5L TDI, Roadworthy certificate 2121.
Encoding: 00001
Operating number: WSC 00000
"One error found:"
P1857 - 35-00 - -
Address 03: Brake electronics
Label file: DRV\4B0-614-517.lbl
Part number: 4B0 614 517 H.
Part: ABS/ESP, all-wheel drive, 1728.
Encoding: 06457
"One error found:"
P1857 - 35-00 - -
Address 08: Climate Control Module. Label file: DRV\4B0-820-043-MY2.lbl.
Part number: 4B0 820 043 AM
Component: A6 Climate Control System, part number 0105.
Encoding: 00103
"One error found:"
01206 - Signal for ignition deactivation duration.
27-00 - implausible signal.
Address 15: Airbag Label file: DRV\4B0-959-655-AI84.lbl
Part number: 4B0 959 655 P
Part: Airbag 8.4EP 2002
Encoding: 0000606
Operating number: WSC 02325 785 00200
"One error found:"
00532 - Power supply voltage.
002 - Lower limit exceeded - Intermittent.
Address 17: Control panel module
Label file: DRV\4B0-920-xxx-17.lbl
Part number: 4B0 920 933 G.
Part: COMBINATION INSTRUMENT + ODOMETER. VDO D11.
Encoding: 00060
Operating number: WSC 00101.
"One error found:"
00771 - Sender for fuel level indicator.
30-10 - Interruption / Short circuit after positive voltage - Occasional.
Address 35: Central locking
Label file: DRV\4B0-962-258.lbl
Part number: 4B0 962 258 L
Component: Central locking system D37.
Encoding: 06721
"One error found:"
00668 - Terminal voltage, terminal 30.
07-10 - Signal too weak - Intermittent.
Address 37: Navigation Label file: DRV\4B0-919-887-BNS4.lbl
Part number: 4B0 919 887 E.
Component: BNS 4.2 H05 BNO 0020
Two error codes found:
65535 - Control unit defective.
00-00 - -
Address 55: Headlight range control. Label file: DRV\4Z7-907-357.lbl.
Part number: 4Z7 907 357.
Component: dynamic LWR D07.
Encoding: 00050
"One error found:"
Address 56: Radio Label file: DRV\8E0-035-1xx-56.lbl
Part number: 4B0 035 195 H
Part number: symphony II NP2 0151.
Encoding: 00231
Operating number: WSC 06342.
"One error found:"
01300 - Control unit for navigation with CD drive (J401).
49-10 - No communication - Intermittent.
Address 76: Parking assist label file: DRV\8Z0-919-283.lbl
Part number: 8Z0 919 283.
Bauteil: Parkingsyst. A6 RDW D08
Encoding: 01116
No error codes found.
Address 77: Phone
Label file: DRV\8E0-862-333.lbl
Part number: 8E0 862 333 A
Component: Nokia 3 0303 phone.
Encoding: 0002033
"Ende" translates to "end" in English.
VCDS
Translated on 05-08-2026, 7:41.
Post23-11-2008, 21:00    Subject: Audi A6: Engine Won't Start - Troubleshooting Guide Quote
Just check if the valve timing is correct, specifically whether the fuel pump rotor is positioned correctly.
Translated on 05-08-2026, 8:03.
chli1976
Post23-11-2008, 21:22    Subject: Audi A6: Engine Won't Start - Troubleshooting Guide Quote
I will check it tomorrow when I have time.
I personally think the VP's wing cell pump is the culprit.
VCDS
Translated on 05-08-2026, 8:04.
luiggi
Post24-11-2008, 18:18    Subject: Audi A6: Engine Won't Start - Troubleshooting Guide Quote
A new fuel injection pump will be required. Best regards.
Post24-11-2008, 19:32    Subject: Audi A6: Engine Won't Start - Troubleshooting Guide Quote
luiggi wrote:
Da wird eine neue Einspritzpumpe fällig werden. Sincerely
I didn't mean to say that...
Translated on 05-08-2026, 8:05.
chli1976
Post24-11-2008, 20:18    Subject: Audi A6: Engine Won't Start - Troubleshooting Guide Quote
Today I checked the valve timing and adjusted the base setting of the VP 44; everything is correct.
In addition, I held the suction hose of the vacuum pump directly into a diesel canister, with the same result.
What would you say, should I get a new ESP (electronic stability program), buy a used one, or have the existing one repaired?
VCDS
mserge
Post25-11-2008, 11:58    Subject: Audi A6: Engine Won't Start - Troubleshooting Guide Quote
Is it new? Does it have a warranty? Can you repair it? Well, it's used, right...?
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 05-08-2026, 8:06.
christians
Post25-11-2008, 12:55    Subject: Audi A6: Engine Won't Start - Troubleshooting Guide Quote
It's probably not worth repairing; there are too many parts that are likely to wear out.
Gruß Christian
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post25-11-2008, 23:54    Subject: Audi A6: Engine Won't Start - Troubleshooting Guide Quote
I personally think it's the wing cell pump of the VP
It usually arrives last.
Translated on 05-08-2026, 8:07.
luiggi
Post26-11-2008, 13:44    Subject: Audi A6: Engine Won't Start - Troubleshooting Guide Quote
I would go for the new one. But negotiate the price beforehand! My old one would have cost around 700€ to be refurbished by Bosch service. I then got a new (Bosch replacement pump) from my parts supplier for around 950€, including VAT (but I'm a good customer there).
I've heard that these things are sold for around €1500 - €1800 in stores, so be careful. Often, there isn't a huge price difference between restoring used parts and buying new ones, when you find the right price. Best regards.
Translated on 05-08-2026, 8:08.
chli1976
Post26-11-2008, 14:50    Subject: Audi A6: Engine Won't Start - Troubleshooting Guide Quote
In Austria, the original price is approximately €2200.
I need to find out how much a replacement pump costs from Bosch.
VCDS
Translated on 05-08-2026, 8:09.
Marco
Post26-11-2008, 17:30    Subject: Audi A6: Engine Won't Start - Troubleshooting Guide Quote
Despite the numerous error messages from the engine control unit (ECU), please check first whether the EGR valve is stuck in the open position. The white smoke that appears only when accelerating could indicate this.
Uli S.
Post26-11-2008, 19:50    Subject: Audi A6: Engine Won't Start - Troubleshooting Guide Quote
Milky fuel indicates the presence of water, and water causes the paper in the diesel filter to swell, which can lead to it becoming clogged (years of experience with watery old fuel icon_evil.gif).
Poppet filter -> Injection start differential.
Without the filter in between? If so, that's bad news. If it's with a filter, please change it, as mentioned above.
Best regards, Uli.
Golf2 GTD AAZ, LLK, CYP
Bus T3 JX
2x Golf2 GTD/SB
97er Golf 3 AFN, 70-100% Pöl
97er Golf 3 Variant AFN
96er Passat 35i AFN
Translated on 05-08-2026, 8:10.
chli1976
Post26-11-2008, 22:01    Subject: Audi A6: Engine Won't Start - Troubleshooting Guide Quote
I tried it without filters.
I've had the EGR system deactivated for a while (I think). It's not my car, but rather my friend's. I need to check again tomorrow, as I'm no longer at the workshop. However, I don't think it's related to that, because I was able to run the engine without the connecting pipe between the two intake manifolds, and therefore without the EGR system.
He called me today and told me that they are now also having problems with the engines where this diesel fuel was used. According to him, there is water and gasoline mixed in with it.
VCDS
Translated on 05-08-2026, 8:12.
chli1976
Post30-11-2008, 16:13    Subject: Audi A6: Engine Won't Start - Troubleshooting Guide Quote
I just installed a new fuel injection pump. I adjusted it using channel 50, and now it's running.
VCDS
Translated on 05-08-2026, 8:13.
luiggi
Post02-12-2008, 17:08    Subject: Audi A6: Engine Won't Start - Troubleshooting Guide Quote
Okay, so the problem is fixed then. By the way, I'm also from Austria: How much did your pump cost?
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts V6 TDI AKN won't start - Troubleshooting Diesel Engine Technology
No new posts Car Won't Start? Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Audi Q7: Won't Start - Troubleshooting Guide Diesel Engine Technology
No new posts 1Z Won't Start: Troubleshooting & Fixes Diesel Engine Technology
