Timing belt (24-01-2003, 8:49)
Torsten
Post24-01-2003, 8:49    Subject: Timing belt Quote
Can there be an increase in diesel consumption after a timing belt replacement? Car: Volkswagen Passat, 110 hp, engine code: AFN.
Where can I find the Ulf setting on the multimeter?
Thank you.
Translated on 08-07-2026, 10:39.
DocSnydor
Post24-01-2003, 9:08    Subject: Timing belt Translating...
[Translating...]Hier!
goro
Post24-01-2003, 9:15    Subject: Re: Timing belt Quote
Can there be an increased diesel consumption after a timing belt replacement? Passat 110hp, engine code: AFN.
Thank you.
Hello Torsten,
Did you replace the timing belt yourself or at a workshop? As far as I know, the engine control unit needs to be checked and possibly reset after a timing belt replacement!
Best regards, Goro.
Translated on 08-07-2026, 10:40.
Michael II
Post24-01-2003, 9:17    Subject: Timing belt Quote
before it once again becomes a major topic:
This has been discussed numerous times in the forum. Further information can also be found in the manuals, technical articles, and the error database.
Please use the search function before posting.
Tschüss
Michael II
Translated on 08-07-2026, 10:41.
Torsten
Post24-01-2003, 10:25    Subject: Timing belt Quote
The ZR (rotor) was replaced in the workshop.
Translated on 08-07-2026, 10:42.
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 ab MJ 98, Zahnriemen läuft auf ESP nicht mittig Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt BLS Diesel Engine Technology
No new posts Zahnriemen Diesel Engine Technology
No new posts Zahnriemen BLB Diesel Engine Technology
