Rene Guest
15-01-2003, 11:46 Subject: SEO-Optimized Title:
**"Best SEO Tools: Find the Right One for You"** |
Hello!
I'm new here and already have a few questions. I converted my T4 from a 1.9L 60HP engine to a complete 2.5 TDI setup (ACV 102HP). I'm having the following problem:
Not normal performance across the entire range of boost pressure. Boost pressure is okay. Mass airflow sensor is okay. EGR system 'failed'.  ESP is activated, timing belt and tensioners are all new, new valve cover gasket, no errors in the memory, new fuel filter, pressure hoses are okay, ESP start is okay; Measured values during driving are okay.
Well, I'm not really sure how to proceed, as I'm not a diesel expert.
Can someone give me a tip?
Thank you very much.
Rene.
Translated on 01-10-2026, 20:25.
Arne Guest
15-01-2003, 15:23 Subject: SEO-Optimized Title:
Okay, let's switch to German... Does your car have no power throughout the entire RPM range?
Have you ever run a benchmark test using Ulf?
Ulf also created a list of potential issues, or whatever it's called, that you could check when troubleshooting performance problems.
P.S. Did you subtract the 1000 mbar for atmospheric pressure when you were conducting your test drive and determining the boost pressure?
arne
Translated on 01-10-2026, 20:27.
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
15-01-2003, 15:25 Subject: SEO-Optimized Title:
Not to mention the underlying conditions...
Just post your measured values. Tschüss
Michael II
Rene Guest
15-01-2003, 16:19 Subject: TDI ACV: Engine Problems & Solutions |
Hello.
I checked the readings during the drive and compared them to the list from the forum. The LD (likely referring to a pressure reading) is around 1900 mbar (which is approximately 0.9 bar), and the ESP timing seems correct. I honestly have no idea what else it could be. It actually runs quite well, but when the turbo kicks in, there's not much more power. The hoses also seem to be okay.
Rene
Translated on 01-10-2026, 20:28.
15-01-2003, 16:39 Subject: SEO-Optimized Title:
Hello Rene,
"However, boost pressure is just one parameter among many. What about air mass, fuel injection volume, and valve timing?"
Again: Did you take the surrounding conditions into account during the measurement? Tschüss
Michael II
Translated on 01-10-2026, 20:29.
Rene Guest
15-01-2003, 17:44 Subject: I don't understand anything anymore?? |
So, I've checked everything one more time.
Coolant temperature approximately 81°C at idle. Display group 0:
1-38
2-50
3-0
4-40
5-94
6-206
7-95
8-179
9-111
10-107
Injection rate: approximately 8.2 mg/h.
I had error code 1242 in the memory! Then I disconnected and reconnected the battery, and I was able to clear the error! I took it for a test drive, and I thought it was going to rip the front axle right off, that's how it started  . What do you think about these values? What could it have been caused by? It's a difference like day and night.
Rene
Translated on 01-10-2026, 20:31.
15-01-2003, 18:01 Subject: SEO-Optimized Title:
Hello Rene,
According to your settings, the coolant temperature is not 81°C. If it were, the value in field 7 would be below 80. Therefore, please consider the operating conditions.
Error code 1242 indicates a problem with the power stages in your engine control unit (ECU). In your engine, the most common cause of this error is the N18 valve (exhaust gas recirculation valve).
Impacts: Reduced performance and increased emission levels.
Please check the AGR.
The exhaust gas recirculation function is checked in function 04.
Default setting. This procedure sets the valve to the...
Exhaust gas recirculation is timed to occur every 10 seconds, so that in the...
Measurement block 003: Extreme values for exhaust gas recirculation.
can be read off.
The advertisement in display field 2.
It must oscillate between the EGR active and EGR inactive states every 10 seconds.
The advertisements in display fields 3 and 4.
must fluctuate within the following range:
"Note:"
Will be displayed in field 3.
a constant value of 550 mg/H.
(fixed replacement value) displayed, check the mass airflow sensor.
AGRn.aktiv
Setpoint display field 3.
450...470 mg/dose.
Setpoint display field 4.
0... 5
AGR.aktiv
240... 280 mg/dose.
95... 100%
"Note:"
The advertisements in display area 3 are printable, and therefore also...
altitude-dependent. The specified values refer to...
0 meters above sea level.
Perhaps something broke while deactivating the AGR (Abgasrückführung).
For the measurement to be accurate, it must obviously function correctly. Tschüss
Michael II
Translated on 01-10-2026, 20:35.
Rene Guest
15-01-2003, 19:10 Subject: SEO-Optimized Title:
Okay.
AGR works  .
'Error cleared. Engine is running very well, but I'd like to know what the problem was. Display group 0.'
1-38
2-52
3-0
4-25
5-95
6-206
7-77
8-179
9-129
10-105
I probably made a mistake earlier in field 77  . But why is the difference between 5 and 6 so large? What exactly can I achieve by changing channels 01 and 03 (ESP amount; Lmm) through adaptation? I'm curious to know if it's easy to make a big mistake there.
Thank you very much, Rene.
Translated on 01-10-2026, 20:39.
15-01-2003, 19:22 Subject: SEO-Optimized Title:
Hello.
To better assess fields 5 and 6, please perform a test run under full load (see the error database).
Please measure block 0.10 and block 11.
Quite a bit has already been written about the topic of adaptation in the forum and the error database. Please take a look. Tschüss
Michael II
Translated on 01-10-2026, 20:40.
Rene Guest
15-01-2003, 19:29 Subject: SEO-Optimized Title:
Thank you so much for the great help!
I'll drive it for a while and see what happens, and whether any more errors occur.
Thank you again.
Rene
Translated on 01-10-2026, 20:41.
