Car won't start, headlights on? (Normal?)
Post17-01-2009, 19:53    Subject: Car won't start, headlights on? (Normal?) Quote
Hi.
Is it normal for a car to not start after being left with the headlights on for 11 hours?
I have LED tail lights (2 W5W bulbs) and 15% amber turn signals in the front.
Theoretically, the 74Ah battery should be able to handle it, but a cold start for a TDI engine also requires a certain amount of reserve power.
Translated on 02-09-2026, 17:05.
Post17-01-2009, 20:57    Subject: Car won't start, headlights on? (Normal?) Quote
That might be possible.
I'm not sure what exactly is powered on in your car when "only" the parking light is on. It's quite possible that the onboard voltage control unit is no longer going into standby mode. And that can draw several amps icon_twisted.gif.
The statement "15% blinker" alone makes me suspect that it's being controlled by the on-board voltage regulator. That would draw a significant amount of power.
Translated on 02-09-2026, 17:06.
Post17-01-2009, 21:13    Subject: Car won't start, headlights on? (Normal?) Quote
Sure, I'll handle the coding for the 15% within the BNSTG.
I can measure the "idle" current later; then I'll know for sure.
I hadn't expected the BNSTG, and I also hadn't anticipated so much power.
Translated on 02-09-2026, 17:07.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post17-01-2009, 21:35    Subject: Car won't start, headlights on? (Normal?) Quote
It is not possible to calculate how much remaining capacity the starter motor has before it no longer spins fast enough, nor how much power is lost due to the cold.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Post17-01-2009, 21:42    Subject: Car won't start, headlights on? (Normal?) Quote
I didn't have that problem with the forester either... After 5 hours with the door open, the little Japanese car icon_wink.gif wouldn't start. icon_twisted.gif
Door open -> 2.5A ... thanks a lot.
Translated on 02-09-2026, 17:08.
No new posts Engine won't start, cranks after start attempt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV 1.9 TDI won't start after fuel pump replacement Diesel Engine Technology
No new posts 1.6 TDI: No dual-mass flywheel with start-stop function Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. AHF ignition coil motor control unit failure - no start (... Diesel Engine Technology
No new posts VAG-COM: No Instrument Cluster Reading Possible On-Board Diagnostics (OBD)
