TDI V6 Idle Tick: Causes & Fixes
Rico_Avant
Post21-08-2008, 15:52    Subject: TDI V6 Idle Tick: Causes & Fixes Quote
I've noticed that when my A6 is idling, it sometimes makes a loud ticking noise, but not always. When I open the oil cap while the engine is running, the noise is reduced or almost gone. What could it be?
Translated on 09-10-2026, 23:24.
Rico_Avant
Post02-01-2009, 22:43    Subject: TDI V6 Idle Tick: Causes & Fixes Quote
No response for almost 4 months? What's going on here? Has anyone else experienced something like this?
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post03-01-2009, 0:43    Subject: TDI V6 Idle Tick: Causes & Fixes Quote
"With the motors, a solenoid valve is constantly activated."
It's nothing special.
However, there's something strange about the oil filler caps.
B.Eng (FH) u. KFZ Meister
luiggi
Post03-01-2009, 15:50    Subject: TDI V6 Idle Tick: Causes & Fixes Quote
If things don't get worse, you can only continue driving and wait. You can at most examine your vehicle for any signs of damage. The hydraulic components can also sometimes cause problems. But as I said, it's pointless to start working on it without knowing the exact cause. By the way, I hardly know any V6 engines that don't have some kind of ticking noise. Just observe it for now. Best regards.
Translated on 09-10-2026, 23:25.
mserge
Post07-01-2009, 11:01    Subject: TDI V6 Idle Tick: Causes & Fixes Quote
Mine started ticking when it got cold and the camshafts were worn. It no longer ticks with the new camshafts.
It was a rather unsettling ticking sound...
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 09-10-2026, 23:26.
grude4
Post20-01-2009, 19:23    Subject: TDI V6 Idle Tick: Causes & Fixes Quote
Hello! V6 engines often have problems with worn camshafts, and it's not uncommon to find broken rocker arms and faulty hydraulic lifters. It's best to disassemble and inspect these components.
Sincerely,
Siba
No new posts Document: Idle running issue, V8 TDI 3.3L AKF engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Engine Knocking Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Misfire: 2.4L & 2.8L Motors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAGCOM: Dashboard Warning Lights Explained Diesel Engine Technology
No new posts Intermittent Engine Misfire: Causes & Fixes Diesel Engine Technology
No new posts Ticking/Knocking Noise in VW Golf Engine (G 4 ARL) Diesel Engine Technology
No new posts TDI Engine Noise: Troubleshooting & Repair Diesel Engine Technology
