V6 TDI AKE Starting Problems: Cold or Warm Engine?
HHdieselpowerHH
Karma: +1 / -1   Thank you, like it!
Post24-08-2008, 21:08    Subject: V6 TDI AKE Starting Problems: Cold or Warm Engine? Quote
Hello everyone, I'm having trouble starting the engine. It starts poorly whether it's cold or warm. I've already adjusted the fuel injection timing to 2 degrees BTDC (Before Top Dead Center), but it didn't work. I've also tried 2 degrees ATDC (After Top Dead Center), but still no luck.
"Set to 0 degrees, but no success. I don't see any air bubbles in the fuel line. What could be the problem with the NHG (knock sensor)? The error memory is empty. When I disconnect the connector from the NHG, there's no change in the engine sound. I think it should be knocking or something, but I'm not sure."
People, please help me, I'm really desperate with my Audi.
Translated on 27-08-2026, 1:23.
exc|sniperg22
Post07-02-2009, 12:21    Subject: V6 TDI AKE Starting Problems: Cold or Warm Engine? Quote
It's been a while, but have you ever replaced the coolant temperature sensor? It's located in the "V" on the right cylinder bank and could be responsible for the issue. The price is around 20€ at icon_smile.gif.
-A6 Avant 2,5 TDi (AKE) 180 Ps TT5 MJ 2001 CHLH; TFL; Nagelnagelnagel.....icon_biggrin.gif
Translated on 27-08-2026, 1:24.
schrauber84
Post10-02-2009, 22:28    Subject: V6 TDI AKE Starting Problems: Cold or Warm Engine? Quote
Before replacing the G 62, check the MWB (Multifunction Wheel Bearing). You can see the sensor value there. Alternatively, check the error memory of the engine control unit or the fuse box. The error is often stored there, but not always.
Translated on 27-08-2026, 1:25.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Passat 3C or Superb 3T emergency unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Valve ticking: New issue with warm engine? Diesel Engine Technology
No new posts Starting problems Diesel Engine Technology
No new posts AAT, 2.5 TDI, year 1996, starting problems, second issue. Diesel Engine Technology
No new posts VW Golf 4 AHF: Starting Problems & Solutions Diesel Engine Technology
