MSG AKN Coding: Guide & Explanation
christians
Post27-01-2009, 21:38    Subject: MSG AKN Coding: Guide & Explanation Quote
I've noticed that, in addition to vehicle type and transmission type, the MSG (Message) also includes a value for Euro2/Euro3. What changes with Euro2 compared to the factory-installed Euro3 setting?
Gruß Christian
Translated on 28-10-2026, 4:26.
mullemaus
Post29-01-2009, 0:04    Subject: MSG AKN Coding: Solutions & Best Practices Quote
I've noticed that, in addition to vehicle type and transmission type, the MSG coding also includes a value for Euro2/Euro3. What changes with Euro2 compared to the factory-installed Euro3 setting?
I would expect a slight decrease in performance. I mean, the Euro III standard might have a slightly higher boost pressure to potentially reduce soot and emissions? However, I don't think the coding can be changed in all cases.
Translated on 28-10-2026, 4:27.
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
No new posts STG Coding: Explained & How-To Guide Diesel Engine Technology
No new posts PLC Programming: Your Guide to STG Coding On-Board Diagnostics (OBD)
No new posts Solved 90% BNS (BCM) T5.2 MDI and FSE coding? On-Board Diagnostics (OBD)
