Rough Idle After Cold Start: Troubleshooting
g1om
Post16-12-2008, 9:31    Subject: Rough Idle After Cold Start: Troubleshooting Quote
Hello everyone,
The never-ending repairs on my Leon ARL are prompting me to ask for your help again.
At the morning temperatures this time of year (approximately 0-5 degrees Celsius), the car starts very well. However, it doesn't run smoothly for the first 5-10 seconds, almost like a misfire in a spark-ignition engine. This is accompanied by a significant drop in the overall voltage of the vehicle's electrical system, which is noticeable in the exterior and interior lighting as 'flickering.'
When I use my auxiliary heater, this problem doesn't occur at all; it starts up and runs smoothly immediately.
Actions taken:
-Error memory query (as always, nothing in it icon_sad.gif).
-Voltage drop measured at battery negative and positive terminals, within acceptable limits (approximately 0.2V during starting).
-All mass points cleaned.
- Glow plug current consumption checked, OK.
- Glow plug control unit swapped horizontally.
-Relays 109 and 100 swapped.
- Battery installed incorrectly (polarity reversed).
- Plausibility check of temperature sensor.
The mechanic had also looked at my car before, but all he could tell me was that the repair would be expensive.
Perhaps I'm also a bit spoiled by my old AFN, which started up perfectly even at -20 degrees Celsius.
Thank you in advance for your help.
Translated on 31-10-2026, 2:43.
Holger247
Post16-12-2008, 10:55    Subject: Rough Idle After Cold Start: Troubleshooting Quote
Even though you've already checked the power consumption of the glow plugs, I would suggest revisiting that aspect.
The high power consumption, the slightly uneven running, and the temperature range suggest that it's a preheating system.
Besides the glow plugs for the engine, there's also a coolant preheating system.
Possible troubleshooting steps include disconnecting the connector to the temperature sensor when the outside temperature is high, forcing the system to preheat at its maximum setting. If disconnecting the sensor also causes the voltage to drop, this would indicate a problem with the preheating system.
Conversely, if the glow plug fuse is blown, the voltage should not collapse; if it does, the fault is likely located elsewhere.
Possibly check the wiring for short circuits.
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 31-10-2026, 2:46.
g1om
Post16-12-2008, 17:48    Subject: Rough Idle After Cold Start: Troubleshooting Quote
I've looked into the glowing issue again and observed the following:
Temperature sensor connected and current draw measured. It's 56A with a cold engine and drops to 45A just before shutdown.
So far so good, then I started the machine, but the voltage dropped again, and the lights flickered.
Then I got a little distracted by the internet, and when I got home, I repeated the whole process again.
During this process, I observed that the glow plugs draw such a high current, even when the engine is warm, that it causes the lights to flicker.
Accordingly, your assumption is heading in the right direction.
Given such high currents, it's likely that the fuse would have blown if there had been a short circuit. However, I can't completely rule out the possibility that the wiring is damaged.
The glow plug control unit is already new, and unfortunately, there's only one ground cable connected to it, which I've already checked and it's in good condition.
Translated on 31-10-2026, 2:48.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post25-01-2009, 7:44    Subject: Rough Idle After Cold Start: Troubleshooting Quote
I wouldn't consider a current draw of 56 amps to be unusual.
You should check the charging voltage with a permanently installed voltmeter.
Regarding your H7 bulb issue, the alternator/regulator might be the cause.
I sprayed CRC on the rusty starter screws of an old VW Golf.
I noticed a spot (while the engine was running) that was emitting steam!
There was an oxidized spot on the crimp connector of the charging cable, which was getting warm and causing the "Caramba" to evaporate!! Voltage drop! icon_wink.gif
High current draw can cause a voltage drop, but it won't cause flickering!
or are you referring to the increased brightness of the lighting when the speed increases?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 31-10-2026, 2:50.
No new posts Document: Idle running issue, V8 TDI 3.3L AKF engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Misfire at High Temperature (PD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Idle Problem: 2.5 V6 AKN Engine Issues Diesel Engine Technology
No new posts A4 2.0 TDI: Rough Idle Troubleshooting Diesel Engine Technology
No new posts AFN: Rough Idle - Troubleshooting & Fixes On-Board Diagnostics (OBD)
No new posts Rough Idle in Hot Weather: Causes & Fixes Diesel Engine Technology
