AMF Funding Duration (KW) & Start (v.OT)
servusssss
Karma: +12 / -0   Thank you, like it!
Post30-01-2009, 20:18    Subject: AMF Funding Duration (KW) & Start (v.OT) Quote
Hello everyone,
After replacing the timing belt on a 1.4 TDI 75 HP, year 2002, engine code AMF, with 88,000 km, I have some questions regarding the target values and actual values.
"Idling fuel trim for cylinders 1-3 (in mg/H): target -2.8 to +2.8, actual value 5 to 23 at idle (I need to check this again with VAG-COM)."
The duration of the boost, in weeks, should be between 4 and 7, and the value is 5.
"Förderbegin" should be in °v.OT and should be 3..9, which is 9.3.
Should I re-take the test, or does it not matter? See:
/viewtopic.php?t=5408
Is the knocking sound during idling due to adjustable valve timing, or are the piston domes (PDs) faulty (if the deviation is correct)?
I installed the timing belt using crankshaft and camshaft timing marks.
The camshaft bearing was significantly out of specification.
Could this be the cause of an earlier start to the subsidy?
Thank you for your replies.
Hello, greetings!
Translated on 27-10-2026, 18:28.
Post31-01-2009, 6:13    Subject: AMF Funding Duration & Start: KW & v.OT Quote
servusssss wrote:
Hello everyone,
"Idling fuel trim for cylinders 1-3, in mg/H: target -2.8 to +2.8, current value 5 to 23 at idle (I need to check this again with VAG-COM)."
My question is, should I readjust the settings, or does it not matter
? In the case of a PD (precision die), the NW (narrow width) setting essentially has no influence on the log values, because everything is controlled purely electronically. Your target values come "only" from the label file and should therefore not be interpreted as a request to readjust.
Translated on 27-10-2026, 18:31.
servusssss
Post31-01-2009, 9:22    Subject: AMF Funding Duration (KW) & Start (v.OT) Quote
and are therefore not to be understood as an invitation to imitate.
Thank you for your answer, ulf, I am relieved icon_biggrin.gif.
Translated on 27-10-2026, 18:33.
No new posts Radio Code: How to Find & Set It Diesel Engine Technology
No new posts Audi 2.5 TDI AKE - Issues with dynamic fuel injection timing Diesel Engine Technology
No new posts A6 4F: Install Horn DWA System On-Board Diagnostics (OBD)
No new posts ??? Which TDI should I choose? Diesel Engine Technology
