Power loss from 2200 RPM... 1.9 TDI PD
marco_A4_avant
2000 Audi A4 Avant
Post03-02-2009, 22:05    Subject: Power loss from 2200 RPM... 1.9 TDI PD Quote
Hello! I drive an A4 1.9 TDI PD with 115 horsepower. For some time now, I've noticed a loss of power starting around 2200 RPM. When I turn the engine off and then on again, it runs well again. Today, I had the error codes read, and this is what came up:
Error code -> Motor -> Motor electronics I.
Error code: 17965
LABEL PRINTING
-INTAKE MANIFOLD PRESSURE TOO HIGH
-sporadic error
Has anyone had similar experiences, have any suggestions for solutions, or just a tip about what might be causing this?
ps: I've just installed a new LLM, and that's not the problem.
"Thank you."
Best regards.
Schöne Kombis heißen Avant
kuestenkuddel
Post03-02-2009, 22:27    Subject: Power loss from 2200 RPM... 1.9 TDI PD Quote
Hi Marco,
Have you ever tried searching for 'Error code: 17965'?
And what? Is there nothing for you?
Best regards, Kurt.
schrauber84
Karma: +1 / -1   Thank you, like it!
Post04-02-2009, 10:27    Subject: Power loss from 2200 RPM... 1.9 TDI PD Quote
Have you checked for any leaks, or if a hose might be faulty?
No new posts Power loss above 180 km/h? Diesel Engine Technology
No new posts Performance loss at 140-160 km/h Diesel Engine Technology
No new posts performance loss, the endless search Diesel Engine Technology
No new posts ladedruck schwankung beim AFN tdi dadurch leistungsverlust Diesel Engine Technology
