VAG-Com Error Codes: Understand & Fix!
VWGOLFIII
Post18-01-2003, 16:53    Subject: VAG-Com Error Codes: Understand & Fix! Quote
Hello.
I read the engine control unit today using VAG-COM because I'm having problems with my car.
The following error codes were stored in the memory:
2 errors found:
01050 - Fuel quantity control servo motor (V117)
31-10 - Intermittent interruption or short circuit to ground.
01204 - Relay for Climatronic (J254)
30-10 - Intermittent fault or short circuit after the positive terminal.
I was able to clear the error codes. However, I haven't done a test drive yet after clearing them. Could it be that the car is running better now?
And what do these errors mean?
Regarding error number two, I can add that I don't have a Climatronic system.
'Could someone please tell me what these errors are called, or where I can find information about them?'
Thank you,
Mark
P.S. The car is a Golf III, manufactured in 1997, with a 1.9L engine, code AAZ, and a turbo diesel (not a TDI!).
Translated on 28-08-2026, 15:30.
Michael II
Post18-01-2003, 17:01    Subject: VAG-Com Error Codes: Understand & Fix! Quote
Hello:
1050: Glow plug monitoring, defect, interruption, or short circuit.
1204: Sensor for engine temperature, defective, open circuit, or short circuit (engine always overheats).
P.S. I saw in your profile that you're a car mechanic. Which brands do you work on?
Tschüss
Michael II
Translated on 28-08-2026, 15:32.
No new posts Fehlercodes Ursachen und Auswirkungen für MKB AMF, ANY Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error Codes, Causes and Effects for MKB ASZ, AXR, ATD Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes 19804/P3348 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Chip Tuning: Understand Engine Optimization Diesel Engine Technology
No new posts TDI with real power Diesel Engine Technology
No new posts 1Z is not working correctly Diesel Engine Technology
No new posts Choppen, aber wie richtig? Transmission, Chassis, Body & Interior
