VCDS: Access to injection start data for CR-TDI engines?
vwSchrauber
Post25-02-2009, 11:40    Subject: VCDS: Access to injection start data for CR-TDI engines? Quote
Can you view the fuel pressure using VCDS on a common rail TDI engine?
In principle, it shouldn't be necessary for "regular" workshops, as the CR system doesn't provide any feedback regarding software updates, and the workshop anyway has no influence on that – quite unlike the VP37 TDIs.
At companies like PSA, the workshop (with its PSA testing equipment) does not have access to the service bulletin (SB).
Has anyone here had experience with the 004 engine control unit (ECU) on a CR-TDI engine?
Greetings.
John.
Translated on 17-07-2026, 3:45.
vagtuning
Post25-02-2009, 23:05    Subject: VCDS: Access to injection start data for CR-TDI engines? Quote
Actually, they should...
MWB 4 (Main injection).
MWB 24.25 and 26 (Pre-injections 1 to 3).
Are values considered 'enough'?
Translated on 17-07-2026, 3:46.
vwSchrauber
Post26-02-2009, 10:04    Subject: VCDS: Access to injection start data for CR-TDI engines? Quote
"Thank you!"
EDIT: Does the pre-injection feature also work on the PD (direct injection) system? According to the documentation, it only has 3 fixed values, independent of engine speed and fuel quantity icon_eek.gif.
Translated on 17-07-2026, 3:47.
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS Diagnostic Issues: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Key role of OBD diagnostic tool / VCDS when buying a vehicle On-Board Diagnostics (OBD)
No new posts VCDS error message on a Seat Ibiza 1.6 TDI CR, year 2010 Upload
No new posts DSG Jerk: 2.0 TDI Starting Issues & VCDS Data Upload
