Intake Valve Cleaning: Remove Carbon Build-up?
ixery
Post23-01-2003, 22:57    Subject: Intake Valve Cleaning: Remove Carbon Build-up? Quote
hello
I have a question about the grime that builds up in the intake manifold, caused by oil vapor and deposits. Is there a way to remove it without removing the intake manifold?
Yesterday, I gave the engine a break and took a look inside the intake manifold. To my surprise, I found a lot of dirt in there. I managed to scrape some of it out with a screwdriver, but you can't really get to everything that way.
Does the intake valve possibly clean itself if no new fuel is added?
ixery
Newly acquired Passat Variant, driven by 'grandpa,' manufactured in 1996 with 110 horsepower and 160,000,000 meters of mileage icon_smile.gif.
Translated on 31-08-2026, 20:14.
haehnlein
Post24-01-2003, 0:18    Subject: Intake Valve Cleaning: Remove Carbon Build-up? Quote
ooooooooh, I can definitely relate to that icon_exclaim.gif ...and at least I had removed the valve cover and cylinder head. Even with strong chemical cleaners (engine degreaser, turpentine, etc.), there was nothing to be done->so everything had to be scraped out meticulously with a screwdriver. The dirt was particularly stubborn in the area of the EGR valve. If such a chunk falls into the combustion chamber or gets stuck between the valve and the head....well, that's a disaster!
So, when it comes to built-in manifolds/heads, I would advise against it icon_exclaim.gif. Perhaps the oil will dissolve some of it over time... but especially with low oil consumption, I find it hard to imagine!
Best regards, Christian.
Translated on 31-08-2026, 20:16.
Post24-01-2003, 12:09    Subject: Intake Valve Cleaning: Remove Carbon Build-up? Quote
Maybe the oil will dissolve some of it over time... but especially with low oil consumption, I find that hard to imagine!
I'm going to assume that if the engine still has its power, I wouldn't take off the intake manifold and cylinder head just because of some gunk.
When I get the timing belt replaced next time, I can shine a flashlight inside to see if it's gotten any better (50,000 km after the noise was discovered).
I don't have too much hope about that, though.
Translated on 31-08-2026, 20:18.
ixery
Post25-01-2003, 10:44    Subject: Intake Valve Cleaning: Remove Carbon Build-up? Quote
Is the paste at your place really hard, or does it have a more viscous consistency, like mine? It's kind of like a porridge and only a little firmer directly around the AGR valve. I guess I'll have to improvise some kind of spoon to get out what I can. I can't say whether I'm experiencing any loss of power because I've only had the car for 2 months.
'My oil consumption is very low, about 0.5 liters every 5000 km, so it probably won't have any further effects, I think.'
In my opinion, it's a design flaw. The poor person who mostly drives their TDI in the partial load range!
Here's another question on the side: Would it be possible to establish a connection between a car and a PC using a multimeter with a PC interface? In other words, could the multimeter be used as a VAG-COM adapter?
best regards
ixery
Translated on 31-08-2026, 20:20.
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clean AGR Valve Without Removal Diesel Engine Technology
No new posts Clean DPF Without Removal: Easy Guide Diesel Engine Technology
No new posts Wheel bearing tool Hazet 4930, no strut removal required? Transmission, Chassis, Body & Interior
No new posts Can the VP37 distribution body be removed without disasse... Diesel Engine Technology
