3BG AVF: Where does the oil come from?
Go to page: 1, 2  Next
Post02-03-2009, 9:11    Subject: 3BG AVF: Where does the oil come from? Quote
Hi.
It's (still) not my car, so I can't do the usual cleaning-driving-looking around thing.
Where could the oil be coming from?
Does it look like an EGR membrane vent hole?!!!?
 File name:  IMG_3771.jpg
 File size:  3.18 MB
 Downloaded:  13335 times
 File name:  IMG_3770.jpg
 File size:  3.12 MB
 Downloaded:  2324 times
Post02-03-2009, 10:20    Subject: 3BG AVF: Where does the oil come from? Quote
My understanding is that since the AGR is controlled by pressure, there shouldn't be any oil leakage from the diaphragm chamber.
The oil leak must therefore be coming from the LL (low-pressure) circuit. I don't know the internal structure, but somehow the EGR valve must be mechanically connected to the internal components. There seems to be a leak on the joint.
Alternatively, the shaft seal of the shut-off valve might be leaking, and the oil seepage could be pushed upwards through the round pipe by the airflow. However, I consider the latter option to be less likely.
Have you tried searching? I seem to recall a post about a drooling AGR.
Guste.
Post02-03-2009, 10:55    Subject: 3BG AVF: Where does the oil come from? Quote
If the bushing where the EGR valve operates is leaking or worn out, the boost pressure can bypass it and end up exactly where the ventilation holes open to the outside.
Post02-03-2009, 11:06    Subject: 3BG AVF: Where does the oil come from? Quote
Okay, then you probably just posted the answer to your own question icon_wink.gif.
Post02-03-2009, 11:21    Subject: 3BG AVF: Where does the oil come from? Quote
No, a theory.
And I would like to have that either disproven or confirmed.
Unfortunately, I forgot to re-check my "AGR valve for future use" when I returned the G3, and then I didn't convert it from the bypass position icon_sad.gif.
You can hear the AGR valve clicking when diagnosing the actuator, so it's probably not completely broken.
Post02-03-2009, 12:12    Subject: 3BG AVF: Where does the oil come from? Quote
dieselmartin wrote:
no, a theory.
Post02-03-2009, 13:54    Subject: 3BG AVF: Where does the oil come from? Quote
Ulf,
Do you perhaps have any recommendations or data on how much valuable boost pressure is typically lost?
The car has 126,000 km on the odometer, and it's possible that I'm the second person to have removed the engine cover (the first was the person who did the timing belt replacement, and they marked it amateurishly with nail polish).
haithamina
Post02-03-2009, 14:53    Subject: 3BG AVF: Where does the oil come from? Quote
From my perspective, the issue seems to be coming from the AGR valve itself, which is supplied with vacuum from above. It's quite possible that the diaphragm inside is damaged! When the AGR valve is open, the exhaust gases enter the intake manifold from below, right? Then you should see high air mass readings at low load and up to 3,000 RPM. Have you checked that? Of course, some unburned fuel could also be leaking through the AGR valve. If it looks like that after 126,000 kilometers, then the pressure is definitely in the single-digit mbar range.
The small side part is actually a valve (the parking valve?). Leakage through its shaft could also cause a loss of LLD (Low-Level Detection). But otherwise, the AGR (Abgasrückführung) part should be sealed. What do you mean by ventilation holes?
haithamina
EDIT: The image of an AGR valve linked here has been removed, as Martin sent two much better ones below.
Post02-03-2009, 15:00    Subject: 3BG AVF: Where does the oil come from? Quote
The membrane is likely NOT broken.
Because you can hear the valve opening when the diagnosis "triggers" it, so it must have been pulled up beforehand. Even if the membrane were damaged, the spring inside would constantly press the valve shut.
Therefore, the only explanation is that the valve is still working, but it's leaking in the shaft towards the membrane.
Thank you for the link. But I'm suspicious of salespeople who don't know what they're selling.
The valve is mounted in a mirror-image configuration for both longitudinal and transverse installations. PD longitudinal motors draw air in from the clutch side, and transversely from the timing chain.
How can a longitudinal valve then be fitted to a Seat (other than an Alhambra)?
haithamina
Post02-03-2009, 15:07    Subject: 3BG AVF: Where does the oil come from? Quote
My only intention was to clarify the internal workings. Everything else is irrelevant to me. It's certain that the AGR valve piston is leaking at the top, as you already mentioned. More specifically, it's the connection between the vacuum sensor at the top and the tube below. No one knows how much leakage is occurring. The AGR valve will likely need to be completely replaced to resolve the issue.
I am unable to translate "haithamina" because it does not appear to be a word or phrase in the German language. It may be a misspelling, a proper noun, or a term from a specialized field. If you can provide more context or clarify the intended meaning, I would be happy to assist you with the translation.
Post02-03-2009, 15:20    Subject: 3BG AVF: Where does the oil come from? Quote
Inside, it looks like this: (a cross-sectional diagram).
/download.php?id=1090
haithamina
Post02-03-2009, 15:32    Subject: 3BG AVF: Where does the oil come from? Quote
Yes.
I understand, and that's why I removed the linked image from my original post. The two images are, of course, much better suited to illustrating the interior.
haithamina
EDIT: Do you know the air mass readings of the car? Should it fit?
Post02-03-2009, 16:14    Subject: 3BG AVF: Where does the oil come from? Quote
No, so far only while stationary (idle and automatic scan).
BM
Avatar-BM
Post02-03-2009, 18:16    Subject: 3BG AVF: Where does the oil come from? Quote
Nobody knows exactly how much LD is released. You will likely need to completely replace the AGR valve to solve the problem
"Mine has been leaking for a while too, although probably not as severely. A loss of boost pressure probably won't be noticeable due to this 'sweating'." To be absolutely sure - which part should be "removed" or "replaced"?
3B5 AJM
Post02-03-2009, 21:13    Subject: 3BG AVF: Where does the oil come from? Quote
I see this very often in almost all "unmaintained" TDI engine compartments! Even after 10,000 km, you'll barely notice any difference after an engine wash; it's only minimal, so don't worry about it!
Post03-03-2009, 7:57    Subject: 3BG AVF: Where does the oil come from? Quote
dieselmartin wrote:
Do you perhaps have any recommendations or measurements of how much valuable boost pressure is lost in that situation.
That's all. Besides the reassurance that the leakage volume flow is likely to be so low that the LD (light detection) will not measurably decrease.
You could try opening the valve with a tool, while wiggling the piston rod, calculate the area of the leak gap, and compare the result with the other cross-sections in the intake manifold icon_wink.gif.
No new posts TDI: Frequent Regeneration? Where Does All the Soot Come ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Clutch Pedal Not Returning Fully Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Where does the water drain? Transmission, Chassis, Body & Interior
No new posts Performance Issues: Why It's Late Diesel Engine Technology
No new posts Turbo Not Coming? Check Status & Updates Now! On-Board Diagnostics (OBD)
No new posts Turbo arrives too late. Diesel Engine Technology
