Soot Formation in AVF Engines
Faxe
Post08-08-2016, 14:31    Subject: Soot Formation in AVF Engines Quote
I have a question about a Passat 3BG, model year 2005, engine code AVF, with 411,000 km on the odometer.
Since the tandem pump was replaced (due to a leak in the vacuum pump).
Increased smoke production during acceleration.
The error memory is empty, and the performance is acceptable to me.
Is there a possible connection to the replacement of the tandem pump?
As far as I understand, too much soot would mean there's not enough air.
Air mass meter readings between 250 at idle and a maximum of 1230.
Boost pressure up to 2100 mBar.
Initial inspection of the intake manifold revealed no issues.
How can I narrow down the problem / find a solution?
Faxes.
Translated on 24-09-2026, 18:10.
Post08-08-2016, 14:45    Subject: Soot Formation in AVF Engines Quote
So, 1230mg/hub @ 2100mbar don't match, which means you have a leak in the charge air duct. icon_wink.gif
Translated on 24-09-2026, 18:12.
Post08-08-2016, 17:37    Subject: Soot Formation in AVF Engines Quote
Hello Faxe,
The car needs an intercooler piping that runs horizontally across the front, underneath the radiator, to the other side. Please check the bends in that piping for any leaks.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post08-08-2016, 19:11    Subject: Soot Formation in AVF Engines Quote
TDI-GTI-4-Motion wrote:
So, 1230mg/stroke @ 2100mbar don't match, which means you have a leak in the charge air duct. icon_wink.gif
Which air mass would be appropriate here?
Translated on 24-09-2026, 18:13.
Post08-08-2016, 21:00    Subject: Soot Formation in AVF Engines Quote
It obviously depends heavily on the speed, but it definitely shouldn't be more than 1050mg per stroke.
Hufe
Karma: +22 / -0   Thank you, like it!
2004 Audi A6 Avant
Post09-08-2016, 9:20    Subject: Wooden Furniture: Buy Online & Save! Quote
With such a high mg/dose, a "chip tuning" modification using a wooden hammer might also be considered...
Beste Grüße,
Hufe
Translated on 24-09-2026, 18:14.
Post09-08-2016, 11:40    Subject: Woodworking: Projects & Ideas Quote
Hufe wrote:
With so many mg/dose, a wooden hammer "chip tuning" might also be considered...
No, because then the boost pressure would be higher. You can't force more air into the same engine without increasing the boost pressure.
The ratio of air mass to boost pressure is quite constant and depends on the engine's displacement, with slight variations depending on the effectiveness of the intercooling system.
Post09-08-2016, 11:53    Subject: Soot Formation in AVF Engines Quote
Right, 1230mg/stroke @ 2100mbar simply doesn't fit with the OEM hardware for that engine, regardless of any chip tuning. icon_wink.gif
The loader is actually applying significantly more force, but that force isn't reaching the sensor.
Translated on 24-09-2026, 18:15.
Faxe
dieselschrauber likes this.
Post10-08-2016, 15:01    Subject: Solved: [Problem/Issue] - Solution & Fix Quote
Yes, Michael and Rainer's assumption was correct: there's a 2cm crack in the pressure hose located behind the turbocharger.
new hose 3B0 145 828 G, 113 Euros at the official dealer icon_sad.gif.
The engine is completely stock, with no modifications.
Thank you for the help icon_smile.gif.
 File size:  66.89 KB
 Viewed:  948 times
Translated on 24-09-2026, 18:16.
Cuddles
2003 Seat Leon
Post30-09-2016, 19:31    Subject: Soot Formation in AVF Engines Quote
I also had an AV fistula. I replaced the shunt three times. Each time, it failed, and I have no idea why.
Translated on 24-09-2026, 18:17.
No new posts Extreme soot formation!! Diesel Engine Technology
No new posts Exhaust Smoke: High Emission at Full Load On-Board Diagnostics (OBD)
No new posts Sooting Issues: Upper Engine - Full Load Upload
