VCDS Scan: User Experience Could Be Better
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post02-03-2009, 13:07    Subject: VCDS Scan: User Experience Could Be Better Quote
Hi.
Is there a way to disable the numerous dialog boxes that appear after saving an Autoscan?
(1) What is the purpose of displaying line numbers 1 through 234 when I save a file?
(2) Why doesn't this dialogue disappear?
(3) Why does *another one* appear when I'm trying to dismiss the 234-line dialog?
Maybe there's a reason for it all, but I find it annoying.
My idea would be:
- Perform a full system scan.
- Click "Save".
- Dialogue with license plate information, etc., will appear.
- After that, you're back at the main menu, and you can close it by clicking on "Close" in the very first menu.
Can "CAN" be set as the default vehicle selection, or does it always display "Please select"?
Greetings.
Translated on 14-08-2026, 0:01.
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. How to create a VCDS scan, and why? On-Board Diagnostics (OBD)
No new posts Golf 8: Missing File During Auto Scan (12/2025) On-Board Diagnostics (OBD)
No new posts Golf 3 TDI: Engine Overheating? Troubleshooting Diesel Engine Technology
No new posts DPF differential pressure slightly high Diesel Engine Technology
