Old MSA with 2x DIL28 - 16-bit?
vwSchrauber
Post26-02-2009, 13:42    Subject: Old MSA with 2x DIL28 - 16-bit? Quote
Hi!
Hab da in unserer Werkstatt ein altes MSA.. ECU unearthed.
On the bracket (which thankfully was included), there is the part number TN 1H1 906 323.
"1H1" refers to a Volkswagen Golf 3. Since the pressure sensor is rated for 200 kPa and the control unit (STG) has a plastic housing, it should be an 8-bit version from the 1Z series.
What I don't quite understand is why an 8-bit microcontroller needs two DIP28 packages, or is it already a 16-bit device?
Please don't laugh, but my area of expertise is more related to EDC16 and EDC17 systems, not those old-fashioned mechanical calculators.
Greetings.
John.
EDIT: The part number for the control unit ends with "021 Q".
Translated on 18-07-2026, 23:35.
Wiesel
Post26-02-2009, 14:16    Subject: Old MSA with 2x DIL28 - 16-bit? Quote
The component also has two processors (8031 cores).
Background: The processing power of a processor is not sufficient icon_lol.gif.
One person is responsible for the engine control functions, while the other handles low-speed control and diagnostics.
Best regards, Micha.
Translated on 18-07-2026, 23:36.
vwSchrauber
Post26-02-2009, 14:27    Subject: Old MSA with 2x DIL28 - 16-bit? Quote
Yes, I saw that. How is the memory organization structured then?
The identifiers 2,287,358,699 and 2,287,358,698 might suggest "low" and "high" respectively, but this is not necessarily the case.
It appears that, based on the circuit board design, each processor is assigned its own memory, and a master coprocessor handles the connection between the two sections.
Translated on 18-07-2026, 23:37.
Wiesel
Post26-02-2009, 14:58    Subject: Old MSA with 2x DIL28 - 16-bit? Quote
No, no. There's nothing about "high" and "low" here. These are two independent 8-bit computers that...
are connected to each other via an ASIC.
Translated on 18-07-2026, 23:38.
vwSchrauber
Post26-02-2009, 15:05    Subject: Old MSA with 2x DIL28 - 16-bit? Quote
That means you have two separate files. One contains the injection parameters, and the other contains diagnostic information and LD (likely referring to "Load Data" or a similar term).
Wiesel
Post26-02-2009, 15:25    Subject: Old MSA with 2x DIL28 - 16-bit? Quote
Yep - that's how it is.
To keep things synchronized, there are also identification fields that are the same in both systems icon_wink.gif.
Abgesehen davon würde ich die Finger von dem alten Schrott lassen. The surrounding context / The extras / The supporting details.
is at least 14 years old.
Translated on 18-07-2026, 23:39.
vwSchrauber
Post26-02-2009, 16:29    Subject: Old MSA with 2x DIL28 - 16-bit? Quote
Besides that, I would advise you to stay away from that old junk.
Curiosity is limitless icon_lol.gif.
The surrounding context.
Date: 12.07.94
Do you perhaps have 2 such (or similar) files? I'd be curious to see how they are structured icon_smile.gif.
Translated on 18-07-2026, 23:40.
Wiesel
Post26-02-2009, 21:19    Subject: Old MSA with 2x DIL28 - 16-bit? Quote
Do you know the quote by Einstein about not being sure about the boundless nature of the universe?
028906021Q
021Q.zip
 File name:  021Q.zip
 File size:  39.95 KB
 Downloaded:  545 times
Translated on 18-07-2026, 23:41.
vwSchrauber
Post27-02-2009, 19:12    Subject: Old MSA with 2x DIL28 - 16-bit? Quote
"Thank you!"
Yes, I know the saying... how true icon_lol.gif.
vwSchrauber
Post06-03-2009, 8:15    Subject: Old MSA with 2x DIL28 - 16-bit? Quote
The thing doesn't even have a WFS icon_eek.gif icon_eek.gif icon_eek.gif.
Translated on 18-07-2026, 23:42.
This topic is locked, you cannot edit or reply. VAG-COM: Old Versions & Downloads On-Board Diagnostics (OBD)
No new posts Old Problems, New Cause: 1Z Explained Diesel Engine Technology
No new posts VAGCOM/OBD2: Optocoupler Adapter for Old 1Z Diesel Engine Technology
No new posts VAG-COM 409: Troubleshooting & Fixes On-Board Diagnostics (OBD)
