P0501 Error Code: Causes and Fixes
Zero-XE
Post14-03-2009, 13:33    Subject: P0501 Error Code: Causes and Fixes Quote
Hello!
I have a fault code P0501, which indicates an implausible speed signal, and the check engine light is on as a result.
Can someone tell me what the consequences are if the engine control unit (ECU) doesn't receive a speed signal? Does the ECU need this signal for learning values, etc.?
The engine is a 1.8T AUQ from a Volkswagen Bora.
Martin
Translated on 13-08-2026, 13:59.
No new posts P0500, P0501, P0502, P0503 - Speed Sensor General Tips
No new posts Error code P1351 General Tips
No new posts ESP function test, error code 01486 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code Diesel Engine Technology
No new posts Fehlercode 2.5 tdi, AAT u.ä. Diesel Engine Technology
No new posts Error code reading On-Board Diagnostics (OBD)
No new posts AFN Error Code 00550: Troubleshooting Guide Diesel Engine Technology
