Hello.
My AJM engine, manufactured in 2003, frequently goes into limp mode under full load at approximately 3000 RPM.
I checked all the hoses for cracks or other damage, and I activated the VTG (Variable Turbine Geometry) using VAG-COM.
Error code: 17965
Boost pressure regulation: Limit exceeded.
In MWB 011, I noticed that the LD (likely referring to a specific measurement or parameter) is different when the system is in a warm state compared to when it is in a cold state.
When the engine is cold, I have 0.979 bar, and when the VTG (Variable Turbine Geometry) is activated, it's 1.09 bar when the engine is warm, but then it goes up to 1.112. Is that normal?
I took a video of the VTG hub.
http://www.file-upload.net/download-1508556/07032009006.mp4.html
Is the path that the rod makes, I/O?
Mathias
