Where does the water drain?
Post16-03-2009, 7:28    Subject: Where does the water drain? Quote
Hi.
After I removed the air filter housing from the Passat, I had trouble remembering where the water drain goes.
I put it in position 1. But when everything was assembled and I put the pictures together for a how-to guide, I realized that version 2 looked better because it has NO moving parts.
At speed 1, the starter motor may spin freely without engaging.
Is there an "official" position on this?
http://tequila.homeip.net/Passat/Wasserablauf.jpg
Thank you.
Translated on 26-07-2026, 10:09.
No new posts TDI: Frequent Regeneration? Where Does All the Soot Come ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Clutch Pedal Not Returning Fully Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Drainage Problems: Where is the Leak? Transmission, Chassis, Body & Interior
No new posts Check Wheel Wells for Drainage: Prevent Rust! Transmission, Chassis, Body & Interior
No new posts 3BG AVF: Where does the oil come from? Diesel Engine Technology
No new posts Performance Issues: Why It's Late Diesel Engine Technology
