RCD500mp3 - Too simple for ID3v2 - Does anyone know anything about this?
Post16-03-2009, 22:23    Subject: RCD500mp3 - Too simple for ID3v2 - Does anyone know anything about this? Quote
The RCD500MP3 is too simple for ID3v2 tags.
icon_smile_thumb_up.gif" color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema für andere Leser nutzlos!
/img140/9968/img1220qa0.jpg" class="responsive" alt="http://img140.
/img140/9968/img1220qa0.jpg" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">
These are encoded in UTF-16 Little Endian and this is indicated by the byte sequence "FF FE". The RCD stubbornly reads and displays these characters.
If you don't use ID3v2, but only IDv1 tags, then everything is fine.
Are there any newer software programs that can display this properly?
I have 0017, but there is also 0018...
No new posts Camshaft Timing: Are You Dumb Enough to Fail? Diesel Engine Technology
No new posts Mengen und DZR am Leon ASV (038 906 012 AT ist doof) Diesel Engine Technology
No new posts ESP Light On, Engine Misfire - Get Help Now! On-Board Diagnostics (OBD)
No new posts Engine Misfire: Troubleshooting & Error Codes On-Board Diagnostics (OBD)
