STG Coding: Explained & How-To Guide
MelleTom
Post25-01-2003, 16:23    Subject: STG Coding: Explained & How-To Guide Quote
How can I code the STG (Steuergerät - control unit) in the AHU (engine type) so that the warning light no longer flashes after a certain time (error: incorrect coding)?
Thank you very much in advance
Translated on 16-10-2026, 2:39.
Michael II
Post25-01-2003, 17:02    Subject: STG Coding: Explained & How-To Guide Quote
What make and model of vehicle (e.g., Golf, Passat...) is this, and what is the model year?
Is it an automatic transmission? What is the error code?
Tschüss
Michael II
Translated on 16-10-2026, 2:40.
MelleTom
Post25-01-2003, 17:08    Subject: STG Coding: Explained & How-To Guide Quote
It's a Caddy model year '97 with a manual transmission and without power steering.
MelleTom
'Additional information: Error code 1551 detected.'
Michael II
Post25-01-2003, 17:28    Subject: STG Coding: Explained & How-To Guide Quote
If it is an MSA 12 control unit (recognizable by the fact that the software version starts with a letter and that there are no leading zeros before the transmission variant SG or AG), it cannot be coded.
For your MSA 15, the value "00002" should be entered.
After programming, be sure to turn the ignition off and on again. Otherwise, the new programming will not be applied.
I actually wanted to know the error code itself, not the error reader's code.
Tschüss
Michael II
Translated on 16-10-2026, 2:41.
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
No new posts MSG AKN Coding: Guide & Explanation On-Board Diagnostics (OBD)
No new posts PLC Programming: Your Guide to STG Coding On-Board Diagnostics (OBD)
No new posts Solved 90% BNS (BCM) T5.2 MDI and FSE coding? On-Board Diagnostics (OBD)
