Shortly after I bought my Ibiza with approximately 23,000 km on the odometer, I noticed that the (airless) charging valve wasn't fully engaging the VTG lever, as if someone had shortened the rod.
As far as I can tell, the factory-applied protective coating was intact, and the LVD (Low Voltage Directives) compliance also showed only relatively small overshoots, which is typical for VTG (Vertical Traveling Grip) rods with shorter stroke lengths.
The MSG software was genuine.
Therefore, I assume that the turbocharger (a GT1749VB) was already adjusted from the factory in such a way that a portion of the possible variable turbine geometry (VTG) range (in the open area) is intentionally sacrificed.
Does anyone know why this might be the case? Is it a specific feature of the Cupra vehicle battery charger?
In all other VAG-VTG turbochargers that I have previously worked on, the can presses the VTG lever against the open stop of the mechanism with slight force
