Torsten Guest
24-01-2003, 7:49 Subject: Timing Belt: Replacement & Repair Guide |
Can there be an increase in diesel consumption after a timing belt replacement? Car: Volkswagen Passat, 110 hp, engine code: AFN.
Where can I find the settings for using a multimeter with Ulf?
Thank you.
Translated on 28-08-2026, 8:54.
DocSnydor Guest
24-01-2003, 8:08 Subject: Timing Belt: Replacement & Repair Guide |
Here!
goro Guest
24-01-2003, 8:15 Subject: Timing Belt: Replacement & Repair Guide |
Can there be an increased diesel consumption after a timing belt replacement? Passat 110hp, engine code: AFN.
Thank you.
Hello Torsten,
Did you replace the timing belt yourself or at a workshop? As far as I know, the engine control unit needs to be checked and possibly reset after a timing belt replacement!
Best regards, Goro.
Translated on 28-08-2026, 8:55.
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
24-01-2003, 8:17 Subject: Timing Belt: Replacement & Repair Guide |
before it once again becomes a major topic:
This has been discussed numerous times in the forum. Further information can also be found in the manuals, technical articles, and the error database.
Please use the search function before posting.
Tschüss
Michael II
Translated on 28-08-2026, 8:56.
Torsten Guest
24-01-2003, 9:25 Subject: Timing Belt: Replacement & Repair Guide |
The ZR (rotor) was replaced in the workshop.
