Clima Flap Motor V71: Location & Troubleshooting
ronny252
Post26-01-2003, 21:52    Subject: Clima Flap Motor V71: Location & Troubleshooting Quote
My air conditioning system (A6, manufactured in 1996, engine AAT, automatic) is displaying an error message indicating that the servo motor for the V71 flap is either blocked or without power.
Where is this valve? Is it located inside the car or in the engine compartment? What's the best way to access it?
Thank you.
Ronny.
Translated on 04-10-2026, 15:03.
Michael II
Post27-01-2003, 12:06    Subject: Clima Flap Motor V71: Location & Troubleshooting Quote
The actuator motor for the back pressure valve is located under the water tank in the engine compartment, on the passenger side. It is mounted under a cover secured with two screws. Underneath the cover, you will find the actuator motor, which is also secured with two screws.
Please also check the wiring of the actuator motor.
Tschüss
Michael II
Translated on 04-10-2026, 15:04.
ronny252
Post29-01-2003, 8:26    Subject: Clima Flap Motor V71: Location & Troubleshooting Quote
"Thank you!"
Ronny.
Translated on 04-10-2026, 15:05.
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coolant fan for Seat Leon 1M (ARL engine) with air condit... Transmission, Chassis, Body & Interior
No new posts Climate control unit malfunction - engine won't start Transmission, Chassis, Body & Interior
No new posts Best Climate: Tips & Solutions Transmission, Chassis, Body & Interior
No new posts Climate Control A4 Malfunction? Transmission, Chassis, Body & Interior
