Question about engine mounts. Defective?
bastion
Karma: +6 / -1   Thank you, like it!
Post26-04-2009, 13:23    Subject: Question about engine mounts. Defective? Quote
Yesterday, while replacing the AGR (air intake control valve) and some seals, I noticed that my left engine mount has a dent in it. Besides the dent visible in the photos, the bearing is bulging outwards.
Is this normal, or is something broken? I'm experiencing a slight jerking sensation when starting up, below 1500 RPM. However, there are no error codes stored, and the clutch and dual-mass flywheel have already been replaced.
Edit: The whistling sound was caused by a leak in the intercooler piping. It is now clean and leak-proof again.
 File size:  81.95 KB
 Viewed:  3090 times
A4 Avant 08/01 AWX 05/08-
vagtuning
Post26-04-2009, 13:30    Subject: Question about engine mounts. Defective? Quote
I would describe that as a good sign.
bastion
Post27-04-2009, 12:13    Subject: Question about engine mounts. Defective? Quote
Okay, thank you. How much does a new bearing cost? It should be around 90 euros plus shipping. Is this a built-in [something]?
No new posts Rear Engine Mount for VW T6 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Mount AFN for Audi A4 Diesel Engine Technology
No new posts Defekt LMM? Diesel Engine Technology
No new posts T4 horn failure Electrical Systems, Vehicle Electronics, Multimedia
No new posts interessanter Defekt beim 1z Diesel Engine Technology
