Replace the charging hose at the turbo (AMF)
Olaf
Post02-05-2009, 20:46    Subject: Replace the charging hose at the turbo (AMF) Quote
I had a problem today on the AB (presumably referring to a car repair or maintenance location) where a fuel pressure hose on my Lupo 1.4 TDI (AMF) burst. Performance suddenly decreased, and there was a terrible whistling sound coming from the deactivated ventilation system.
Over time, the performance loss became increasingly severe, and the engine went into emergency mode.
When you remove the underbody panel, you'll hear a distinct whistling sound coming from the front right when driving, and no more air will come through the ventilation.
The car has always had a slight oil leak through the breather hose (coming from the intake manifold) to the turbo. Therefore, the vacuum hose is also slightly oily on the turbocharger.
On the other rubber hoses, there are no visible damages. The one on the turbo is unfortunately so difficult to reach that you can't really examine it properly.
In the error memory, it logically states:
17964 - Charge Pressure Control: Negative Deviation
35-10 - - - Intermittent
Is there any trick to getting to the hose from below and checking/replacing it properly?
This is very tight between the suspension parts, and you can barely get a hand in...
Are my thoughts correct that it's probably the oily hose? Or do you see it differently?
The problem is that I have to drive over 300 km every day, starting Monday, and I really don't want to rent a car right now. Therefore, I would be grateful for tips on how I can do this myself, as I will have little time on Monday morning to avoid making further mistakes due to misdiagnosis by repair shops.
Managed to get an open workshop today to check, but unfortunately, it didn't confirm all my theories about the fault codes, especially because it seemed to be building up some boost pressure, but nothing was visible. They naturally then came up with LMM and similar theories about jokes.
Thanks for the tips!
Olaf
Back to top Profile PM Email
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post02-05-2009, 22:59    Subject: Replace the charging hose at the turbo (AMF) Translating...
[Translating...]
Hi Olaf vorne rechts sitzt der LLK und die Verrohrung,
mit "Durch die Lüftung pfeift nichts mehr" kann ich nichts anfangen icon_rolleyes.gif
erst sagst du der Schlauch sei geplatzt, ja dann müsste man doch einen Riss sehen.
Wenn es pfeift solltes du das Lec ja ausfindig machen können, notfalls alleine mit Leck Suchspray und Gasgeben??
300 km fahren im Notlauf, das kannst du vergessen.
Edit; möglicherweise ist ja auch ein Dichtring am Schlauch rausgeflogen?
Da kommst du ohne Hebebühne schlecht dran, Ich meine die rechte Radhausschale sollte raus damit man an den LLK kann.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Olaf
Post02-05-2009, 23:15    Subject: Replace the charging hose at the turbo (AMF) Translating...
[Translating...]
Vorne rechts am LLK isses OK... Hab ich als erstes geschaut. An den LLK komme ich beim Lupo auch so nach Abnehmen des Unterbodens.
Durch die Lüftung pfeift es nicht mehr, seitdem ich unten die Unterbodenabdeckung abgenommen habe, pfeift der entweichende Ladedruck nicht mehr durch die Lüftung in den Innenraum rein. D.h. bei dem Phänomen mit der Lüftung handelt es sich wohl nur um Staudruck unter der Haube von dem entweichenden Ladedruck.
Geplatzt ist der Schlauch ja nicht sichtbar, es pfeift nur tierisch raus, wenn Druck anliegt. Es muss also irgendwo ein Leck geben.
Mir gehts eher darum, wie ich an das Schlauchende am Turbo vernünftig rankomme. Das ist auch von unten nicht so leicht erreichbar.
Der Tipp mit den Schlauchdichtungen ist vielleicht gar nicht so blöd...
Nur zumindest an der LLK-Seite war bei mit auch nie so ne Dichtung drauf!?
Wie funktioniert der "Suchspray"??? Blasenbildung usw. kann ich ja nicht beobachten, da es nur rauspfeift, wenn mehr Ladedruck anliegt als man ohne Last auf der Bühne simulieren kann.
Bei Vollgas im Leerlauf ist alles normal.
Achja, 200 km bin ich notgedrungen damit heute schon gefahren. Die ca. 330 km stehen auch nur Montag an. Die Tour kommt dann in der Woche noch mindestens 2x zusätzlich drauf. Ist recht nervig mit Notlauf.
Gruss
Olaf
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post03-05-2009, 10:45    Subject: Replace the charging hose at the turbo (AMF) Translating...
[Translating...]
Das Luft- Blasenspray würde ich an die vermutete Stelle und nur einmal kurz auf 2000 Vollgas fahren bie zum ersten An- Pfiff. Dann drunterlegen schauen wo eine Blase ist.
Der Schlauch muß halt runter und wenn eine Dichtung drin ist nachsehen.
Das was die Dichtungen durch Ölschwitzen an Lade Luft durchlassen reicht imho nicht für einen Notlauf. Da sollte mehr sein, evtl. auch der LLK gerissen?
Karma: +437 / -0   Thank you, like it!
Post03-05-2009, 11:11    Subject: Replace the charging hose at the turbo (AMF) Translating...
[Translating...]
Olaf,
Ich bin mir beim AMF nicht sicher, meine aber, er hätte noch den alten Wastegatelader und eben noch keine VTG.
Sofern ich damit richtig liege, killst du den bei Fahrten im Notlauf! Ein Wastegatelader kann über das Motorsteuergerät nur auf einen _höheren_ Ladedruck geregelt werden, als dieser mechanisch vorgegeben ist. Ich weiß die Zahlen nur am Beispiel des 1Z: Dieser war mechanisch auf 0,6 bar geregelt und wurde vom MSG auf 0,9 bar Überdruck hochgeregelt. Die 0,6 bar werden aber selbst im Notlauf versucht einzuregeln, da dies mechanisch so vorgegeben ist.
Fährst du jetzt im Notlauf mit geplatzten LD-Schlauch, so kann der Lader ziemlich schnell Schaden nehmen!
Also: Erst Fehlersuche + Reparatur, dann weiter fahren! Sonst droht ein Laderschaden mit entsprechenden Folgen.
Bereits mit leichter Last (elektrischer Verbraucher, ggf, Klima, etc) sollte bei moderater Drehzahl auf der Bühne bereits ein deutlich fühlbares Luftentweichen an der Leckstelle stattfinden.
Guste
Olaf
Post03-05-2009, 11:33    Subject: Replace the charging hose at the turbo (AMF) Translating...
[Translating...]
Danke für die Tipps. Ja, es ist nen Wastegatelader, der sich im Notlauf auf 0,6 bar einpendelt.
Das Problem ist halt, dass beim Testen im Leerlauf (egal welche Drehzahl) kein hörbares Entweichen von Luft zu hören ist, selbst wenn man oben an einen der Gummischläuche zusammenquetscht. Wenn man dann beschleunigt, ist der Schlauch mit den Händen nicht mehr gequetscht zu halten, es pfeift aber nirgendwo raus.
Deswegen hat mich die Werkstatt gestern erstmal nach Hause zum Fehlerspeicher auslesen geschickt. Die glaubten noch nicht so an den kaputten Schlach. Haben aber auch definitiv von TDIs noch weniger Ahnung als ich. Das hat sich schon gezeigt.
Über nen Riss im LLK habe ich auch nachgedacht. Dagegen spricht aber, dass
1.
bis zu einem bestimmten Ladedruck kein spürbarer Druckverlust auftritt,
2.
Bei montiertem Unterbodenschutz der Ladedruck extrem in die Innenraumbelüftung geht und die saugt da vorne beim LLK nix an und dort könnte der Druck wohl noch ganz gut nach außen entweichen,
3.
das Pfeifgeräusch ziemlich nah von der Spritzwand vorne rechts kommt, wo der Turbo sitzt.
Das super Blasenspray krieg ich im Baumarkt, in Werkstatthandel oder wo?
Olaf
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post03-05-2009, 11:57    Subject: Replace the charging hose at the turbo (AMF) Translating...
[Translating...]
Richtig, LLK eher nicht, wenn es nicht gleich und dauerhaft pfeift,
Bei Gas / Wasser / Sch.. Install bedarf oder Wohnmobil Heizung gibt es das Spray.
Ich habe ZB Alltec Leck Suchspray biologisch abbaubar.
http://www.mercateo.com/p/147-13245010044/Lecksuchspray_100_ml.html
Oder misch dir was mit Schaummittel von der FW. In eine Blumenspritze?
(edit: Das Spray eignet sich eher für das Suchen kleinerer Lecks)
Wenn du schon weißt, dass es in der Nähe der Lüftung pfeift dann...bläst es auch dort wo raus.
Die Profis haben sich 2 Deckel für die LL Rohre gebastelt, einer mit Druckluftanschluss da 1 bar drauf.. icon_idea.gif
Olaf
Post03-05-2009, 19:31    Subject: Replace the charging hose at the turbo (AMF) Translating...
[Translating...]
So, der Heini in der Werkstatt am Sa. war einfach nur blind bzw. seine Taschenlampe so funzelig, dass ich das Loch auch nicht gesehen habe.
Hab einfach ne richtige Lampe reingelegt und mich mal unters Auto gelegt und meine Frau aufs Gas treten lassen.
Ist nen fingerbreiter Riß in dem Gummirohr direkt am Turbo auf der Innenseite zum Motorblock hin. Die Sache ist jetzt notdürftig mit X Lagen Panzertape geflickt und wird dann in ganz naher Zukunft ersetzt, sobald ich das Schlauchteil hab.
Auf jeden Fall danke für die Hilfe.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post03-05-2009, 19:53    Subject: Replace the charging hose at the turbo (AMF) Translating...
[Translating...]
siehste icon_biggrin.gif hoffentlich hält das den Panzer wenn der heiß wird
Olaf
Post03-05-2009, 20:03    Subject: Replace the charging hose at the turbo (AMF) Translating...
[Translating...]
Viel Vertrauen hab ich nicht in die Rep.
Sobald ich das Teil habe, tausche ich den Schlauch.
P.S.
Nur zur Info:
Das Schlauchende hat mich 25 Euro + Steuer gekostet. Naja, hält ja hoffentlich auch ne Weile.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts Werkstattaktion 2D, Glühkerzen-STG tauschen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts Thick-walled intake air hose for turbo Diesel Engine Technology
No new posts Where to attach the boost pressure hose Diesel Engine Technology
No new posts What adhesive should be used to glue a turbocharger boost... Diesel Engine Technology
No new posts ATF change for A6 TDI AKE Diesel Engine Technology
