Golf 3 Steering Column Noise: Causes & Fixes
reuselkopp
Post15-05-2009, 13:22    Subject: Golf 3 Steering Column Noise: Causes & Fixes Quote
Hello everyone,
"I've been hearing a creaking noise coming from the steering column for a while now. It only occurs when the interior of the car is warm. What's strange is that the noise is audible even when driving straight (no steering input). I mean, when driving over bumps, it creaks. What could it be? Does something need to be lubricated or oiled?"
Greetings.
Reuselkoppmania.
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 06-10-2026, 4:45.
Post15-05-2009, 14:14    Subject: Golf 3 Steering Column Noise: Causes & Fixes Quote
My G3 Var made a creaking sound when I turned it on... I also think it made the sound when it was warm.
After no one could find it for over a year or two, and I was once again lying under the car, taking pictures and looking at the engine, I decided to adjust the tie rod ends (a few degrees makes a difference).
UI, creaking...
It was fixed by replacing the two tie rod ends!
Translated on 06-10-2026, 4:46.
No new posts Tankklappenentriegelung failure Golf 5 Variant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dacia/Renault Duster, squeaking noises steering column / ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touareg documentation, clacking sounds coming from the st... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rattling front axle, driver's side, Golf 3, what could it... Transmission, Chassis, Body & Interior
No new posts Turbocharger: 255 HP - Is That Possible? Diesel Engine Technology
No new posts What could be causing the loading pressure issue? Diesel Engine Technology
No new posts 00575 - Intake manifold pressure: What could it be? On-Board Diagnostics (OBD)
