Passat Tire Wear: 3B Sedan, 98, 110 HP AFN
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Kradmelder
Post19-02-2003, 12:06    Subject: Passat Tire Wear: 3B Sedan, 98, 110 HP AFN Quote
Hello everyone,
Regarding the Conti Sport Contact tires, size 205/55 R16, 91 W, I'm experiencing the following problem: The rear tires develop a 'sawtooth' pattern (uneven wear) at a tread depth of approximately 4 mm, which creates very annoying humming noises. My driving style is calm, mostly highway driving, and the tire wear is very low (85,000 km with this set). The shock absorbers have been tested and are in good condition. Does anyone else experience this problem? Could it be related to the brand of tires? What other tire brands or models would you recommend?
Kradmelder.
Translated on 28-07-2026, 14:16.
ixery
Post20-02-2003, 23:41    Subject: Passat Tire Wear: 3B Sedan, 98, 110 HP AFN Quote
'This problem isn't just specific to these tires. It's typical for block-pattern tires that are 'eternally' mounted on the rear axle of a car. My suggestion is either to buy tires with a V-profile or to rotate them from front to back more frequently.'
ixery
Translated on 28-07-2026, 14:17.
No new posts LED Rückleuchten Retrofit for Audi A6 4F Saloon Troubleshooting & Guides
No new posts Standheizung in Passat 3BG einbauen Troubleshooting & Guides
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 98er Golf 4 1,8T AGU MSG an 98er Polo 6N WFS anlernen HILFE! On-Board Diagnostics (OBD)
No new posts Poltergeräusche Vorderachse 98er Passat 3B, AFN Transmission, Chassis, Body & Interior
No new posts Aero Frontscheibenwischer nachrüsten am 98er Passat Transmission, Chassis, Body & Interior
No new posts Differences between the 96 AFN (Golf 3) and the 98 AFN (P... Diesel Engine Technology
