TDI with Common Rail: Explained & Benefits
Go to page: 1, 2  Next
Thomas
Post11-01-2003, 14:38    Subject: TDI with Common Rail: Explained & Benefits Quote
I stumbled upon this information randomly on the Wendland website.
It also includes a list of all the modifications made to transform the standard engine into a high-performance TDI racing engine with 200 horsepower.
http://www.wendland-tuning.de/html/tdi_r_147_kw_common-rail.html
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 16-08-2026, 6:35.
diesel.gustav
Post11-01-2003, 23:38    Subject: Best German Coffee: Taste & Reviews Quote
Deleted upon request.
Translated on 16-08-2026, 6:36.
Post12-01-2003, 6:43    Subject: Things That Amaze Me Quote
Hi Gustav,
... is that the base engine is specified as a 1.9-liter with common rail (CR) technology.
"By 'base,' I mean a standard engine, but currently, there isn't a 1.9L VAG CR-TDI available... or is Wendland modifying a VAG in-house CR racing TDI to produce 200 hp / 400 Nm?"
Or is the information on the website simply nonsense, at least regarding the base engine?
Translated on 16-08-2026, 6:37.
Thomas
Post12-01-2003, 10:43    Subject: TDI with Common Rail: Explained & Benefits Quote
Should everyone now fall to their knees in awe, or are you expecting a statement on this matter?
I'm posting this here because I randomly found it on the Wendland website, and I thought that some people might be interested in it. Perhaps it could even lead to a new discussion icon_idea.gif.
@Ulf
I was wondering the same thing.
Despite everything, best regards icon_smile.gif.
Thomas.
Translated on 16-08-2026, 6:38.
Manuel Thomas
Post24-01-2003, 23:33    Subject: TDI with Common Rail: Explained & Benefits Quote
I'm surprised that Wendland made the conversion to 200 horsepower seem so complicated, or is it just a bunch of nonsense?
One would need to know what type of base motor was used.
If you've already used a VP-TDI engine, this conversion shouldn't be too difficult, as long as you can secure the fuel pump and injectors properly.
But the effort required is far too much!
Take a PD engine with 130 hp TDI power, replace the VNT17 turbocharger with a VNT20, modify the intake system, increase the intercooler threefold in size, install an exhaust system designed to reduce back pressure and include a metal catalytic converter. Depending on needs, you can also add a tropical-type water cooler and an oil cooler.
After software programming adjustments, achieving around 200 horsepower and over 400 Nm of torque is possible without compromising the engine's durability.
Manuel.
Translated on 16-08-2026, 6:41.
Gremlin
Post25-01-2003, 11:16    Subject: TDI with Common Rail: Explained & Benefits Quote
To get back to the topic.
VW has already publicly acknowledged in industry publications that they are developing a common-rail system because the PD technology is reaching its limits, especially with regard to exhaust emissions and fuel consumption. Particularly when combined with particulate filters or NOx storage catalysts, a common-rail system is essential because it provides absolute freedom over injection timing (keyword: post-injection).
CU Gremlin.
Translated on 16-08-2026, 6:42.
Manuel Thomas
Post25-01-2003, 11:25    Subject: TDI with Common Rail: Explained & Benefits Quote
@ Gremlin
Unfortunately, I have to disagree with you. VW is continuing to use the PD (Pump Denoise) technology. If you examine the operating principle of the PD units closely, you will realize that they achieve the most homogeneous injection among all injector elements.
Why would VW develop a new 2.0L PD-TDI engine when they intended to switch to common rail technology? Audi is gradually transitioning to common rail in order to differentiate itself from VW. They started with the 3.3L V8 TDI, and the new 4.0L TDI will also be a common rail engine.
Have you ever seen a diesel engine that meets Euro 4 standards without using common rail (PD) technology?
Manuel.
Translated on 16-08-2026, 6:44.
Ernst S.
Post25-01-2003, 12:04    Subject: Piezo Technology: Applications & Benefits Quote
Hello!
Volkswagen and Siemens plan to build a joint plant. The purpose is to introduce piezo common rail injection systems at Volkswagen.
That doesn't mean that PDs will simply disappear overnight.
Certainly, the method using piezoelectric crystals offers enormous possibilities. It allows for multiple pre- and post-injections to reduce emissions.
Certainly! Please provide the German text you would like me to translate into English. I will only provide the translation.
Translated on 16-08-2026, 6:46.
kenny
Post25-01-2003, 17:15    Subject: TDI with Common Rail: Explained & Benefits Quote
VW has actually been using common rail diesel engines in its vans for quite some time.
Perhaps the 2.0 PD with 16V is just a transitional engine, used to avoid falling behind in competition, because common rail engines are not yet sufficiently advanced at Volkswagen?
Volkswagen has internally admitted to having been complacent in the development of diesel technology. In fact, I once read a report suggesting that Mr. Piech accused the head of the development department or someone similar of this.
Translated on 16-08-2026, 6:47.
Mampf
Karma: +8 / -1   Thank you, like it!
Post25-01-2003, 21:02    Subject: TDI with Common Rail: Explained & Benefits Quote
Manuel Thomas wrote:
Which LT engine is a common rail?
Manuel
Hi, the 2.8L.
see: http://www.vw-nutzfahrzeuge.de/index.html?technik/lt_28tdi_motor.html
Crunch.
@ Manuel Thomas - it seems like you are ahead of your time; for me, it's currently 21:05 icon_biggrin.gif.
Translated on 16-08-2026, 6:48.
Manuel Thomas
Post25-01-2003, 21:28    Subject: TDI with Common Rail: Explained & Benefits Quote
Which LT engine is a common rail engine?
Manuel.
Translated on 16-08-2026, 6:49.
Gremlin
Post25-01-2003, 23:03    Subject: TDI with Common Rail: Explained & Benefits Quote
@manuel
I will put the announcement online sometime during the course of Monday icon_wink.gif.
CU Gremlin.
Translated on 16-08-2026, 6:50.
Lanz
Post26-01-2003, 12:29    Subject: Common Rail: VW Repair & Maintenance Guide Quote
The 2.8L engine in the LT is a common rail engine. The engine code is AUH.
VW is also continuing to work on common-rail engines. Indeed, it appears that pump-injector technology is reaching its limits in terms of development potential.
It seems that this has been assessed differently up until now.
Best regards, Lanz.
joergs
Post26-01-2003, 12:48    Subject: TDI with Common Rail: Explained & Benefits Quote
Check out Erwin's page; there's an information sheet about the VW CR diesel engine!
Translated on 16-08-2026, 6:51.
Post26-01-2003, 14:02    Subject: Common Rail VW: Problems & Solutions Quote
Lanz wrote:
The 2.8 liter engine in the LT is a common rail. The engine code is AUH.
VW is also continuing to work on common-rail engines. Indeed, it appears that pump-injection technology is reaching its limits in terms of development potential.
It seems that it has been assessed differently up until now.
The engine from the LT is a purchased component from a Brazilian manufacturer. Volkswagen itself does not plan to use any common-rail (CR) engines.
For the LT, a large-volume diesel engine was needed as quickly as possible, and therefore the 2.8L CR engine was installed (it was not desired to purchase it from DC... icon_smile.gif).
Audi is currently developing Common Rail (CR) engines and they are likely to be used in the next generation of six-cylinder models. The Pumpe-Düse (PD) technology is currently only feasible up to five cylinders, which is why the V10 PD TDI is essentially a twin five-cylinder engine.
The development of pneumatic technology is far from over. It would be very detrimental because it is widely used in the truck sector, and the current state of the art (see the DC Actros) demonstrates this.
Currently, the PD Tewchnik is the only one capable of meeting the 2004 emission standards without additional particulate filters (which Volkswagen absolutely opposes).
Translated on 16-08-2026, 6:53.
Manuel Thomas
Post26-01-2003, 15:20    Subject: TDI with Common Rail: Explained & Benefits Quote
Common rail technology has been around for a while, even in trucks. At Volkswagen, engineers were still working on the TDI engine with a unit injector pump.
Manuel.
Translated on 16-08-2026, 6:55.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Common Rail vs. TDI: Which is Better? Diesel Engine Technology
No new posts Common Rail Injectors: LT 35 Refurbishment? Diesel Engine Technology
No new posts Common Rail Tool Set for Timing Belt Replacement Diesel Engine Technology
No new posts Injector Code Input (Common Rail) On-Board Diagnostics (OBD)
