Doku Sharan 7M9, Engine Noises at MKB ANU (Solution)
Michael II
Post29-01-2003, 11:56    Subject: Doku Sharan 7M9, Engine Noises at MKB ANU Quote
Motor noises similar to a timing belt at MKB ANU
Affected Chassis Numbers:
Until 7MY V 024641
Cause
Noises are generated in the pre-heating valve (diesel filter element) and are then transmitted through the fuel return line to the vehicle interior.
Solution:
To investigate sound transmission, the steel return line at the filter must be cut. Cut out the 70 mm section and replace it with a fuel hose.
Fuel hose No. N 103 035.01, Length 180 mm
Cable Tie No. N 102 922.01 x 3
Tschüss
Michael II
Ratings - Doku Sharan 7M9, Engine Noises at MKB ANU
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Noise in Car: A6 4B (1999) Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BMW 320d Engine Noises: Listen & Diagnose (MP3) Diesel Engine Technology
No new posts AGR Seat for VW Sharan 7N Diesel Engine Technology
No new posts Faulty Sharan Control Unit - Replacement & Repair On-Board Diagnostics (OBD)
No new posts VW Sharan Diagnostic Connector Diesel Engine Technology
