Kolbenring Blaumann
Joined: 09/09/2006 Posts: 35 Karma: +6 / -1 Location: Limburg
18-07-2009, 23:20 Subject: Fuel Injection Error 00550: Troubleshooting Guide |
Hello everyone,
My V6 TDI (150 hp, engine code AKN) has a problem. The error memory indicates an issue with the fuel supply or injection system. So, I went to the forum and read what's known about this error. What I read wasn't very encouraging; it seems it could become expensive. So, I first checked and addressed the "simple" things, i.e., I replaced the diesel filter and checked the fuel injection timing. It was slightly off, about 5° too early, but that wasn't the cause. It starts perfectly, but it didn't help. When I changed the filter, I noticed something. When I disconnected the fuel line, no diesel came out. I filled the filter through the inlet. Then I thought, "Let's try starting it," and I directly supplied fuel from a canister into the filter. It ran, but the "problem" was still there. In any case, the fuel line to the filter was still open, but no diesel was coming through. I thought there should be a good flow of fuel. So, I checked the fuse for the pre-lift pump, everything was fine. The dealer replaced that pump last year; my wife was driving when it happened. My first question to the experts: "How can I test the pre-lift pump or put it in continuous operation? Besides the fuse in the fuse box, is there another one hidden somewhere? Can I get a new one from an aftermarket supplier, or do I have to go to the dealer?" If this pump is working, I probably have a bigger problem, i.e., I have to sell the living room furniture and buy a new injection pump. My second question: "Who in the Munich or Frankfurt/M. area can professionally and at a reasonable price test and possibly repair VP44 pumps?" Are there any experiences or recommendations in this area? Thanks in advance.
Translated on 02-11-2026, 13:52.
A6 Andreas Blaumann
23-07-2009, 7:07 Subject: Fuel Injection Error 00550: Troubleshooting Guide |
Okay, so the pump in the tank only fills the dust container in the tank, allowing the ESP system to draw in air freely, even when driving around curves.
You actually don't need them when the tank is full.
Your ESP is self-priming.
Since it's self-priming, a vacuum is created in the suction line, so everything must be airtight. You should check the clear hose at the top for any air bubbles.
"MFG" is an abbreviation for "mit freundlichen Grüßen," which means "best regards" or "sincerely." It is commonly used in German-language emails and letters.
Translated on 02-11-2026, 13:55.
23-07-2009, 8:34 Subject: Fuel Injection Error 00550: Troubleshooting Guide |
What exactly is the "problem"? MfG. Michael
Profile PM Garage |
Kolbenring Blaumann
23-07-2009, 13:44 Subject: Fuel Injection Error 00550: Troubleshooting Guide |
First of all, thank you for the explanation. In the meantime, I've come across many websites that deal with this topic in some way. However, not all of the articles were encouraging.
I had secretly hoped that the pre-pump would solve the "problem." But now, all the posts seem to suggest that a pre-pump isn't necessarily required (which it definitely is), and my ESP is just completely messed up. That would mean a 1500€ problem. That's why I'm asking about a service that can a) inspect the ESP and b) repair it. Since I've pretty much exhausted all other possibilities, the pre-pump is the only option left before I have to replace the ESP. We'll see what happens; I'll have to set aside some time this weekend. I'll let you know how it goes.
Translated on 02-11-2026, 13:56.
23-07-2009, 14:17 Subject: Fuel Injection Error 00550: Troubleshooting Guide |
Hey, do you not want any help? MfG. Michael
Translated on 02-11-2026, 13:57.
Profile PM Garage |
DieselBär30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: München & Passau
25-07-2009, 9:25 Subject: Fuel Injection Error 00550: Troubleshooting Guide |
Hello everyone!
@ 4-Motion : No, he's just trying to ignore you because you don't want to buy his living room cabinet for 1,500 euros *laugh*.
@ Kolbenring : Obwohl ich Deinen Wohnzimmerschrank auch nicht haben will, täte ich trotzdem gerne wissen, wie bzw. in welchem GENAUEN Wortlaut Dein Fehlerspeicher auf ein "Problem in der Kraftstoffversorgung" hinweist. Vielleicht stimmen da Deine Steuerzeiten nicht?! Vielleicht bekommt Dein Motor irgendwie nicht genug Luft und das MSG versucht das auszuregeln? Maybe...
Otherwise, we can all just take out our crystal balls and regret that you don't have ESP  .
Best regards from Munich!
PS: The woman at the gas station might have already damaged or even completely destroyed the VP44 fuel injection pump. 1. S.verlängerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
Translated on 02-11-2026, 13:58.
Kolbenring Blaumann
27-07-2009, 17:30 Subject: Fuel Injection Error 00550: Troubleshooting Guide |
Hello.
No, I'm not ignoring GTI, TDI, or 4Motion. But I don't think I'm explaining myself clearly. Sorry if that's the issue.
Let's go back to the beginning. The "problem" starts with the vehicle not revving beyond 2000 rpm and only emitting smoke. Everything else seems fine. The starting behavior is excellent, and the acceleration is smooth, but only up to 2000 rpm. The error memory shows error code 055000, with the comment "Injection timing/regulation difference." I've learned that this is related to fuel delivery, and the issue likely lies there.
I noticed that the vehicle has a strong smell of oil.
What have I checked or replaced so far?
- Fuel filter -> replaced; it was found that the VFP (Variable Fuel Pump) is not working.
- The VFP (vehicle front panel) has been checked, and it's not working properly. An additional €400 is required, which is frustrating because it was replaced just 2 years ago.
- Relay -> OK.
- Fuse -> OK / In order.
- Start time check: approximately 3° too early. Correction did not improve the result.
Now, here are my questions:
- VFP, could this be the cause? Or is this just an auxiliary component? People seem unsure, at least based on what I'm reading. Regardless, I've installed an electric booster pump to get the diesel to the ESP -> no improvement.
- Are there any other possible causes for the error? I heard about the LMM (likely mass airflow sensor), but wouldn't that trigger an error code in the diagnostic system?
- Need to get an ESP (Electronic Stability Program) check done. Does anyone know of any reputable places in the Munich or Frankfurt area? Share your experiences.
- There are a variety of differences between different ESP models, and some of these differences are not always clear. For example, can I replace an ESP with identifier 106B (I'll omit the rest of the details) with an ESP with identifier 106H? Is there a list or any experience available regarding the various identifiers and the changes that have been made? I imagine there might be differences related to manual vs. automatic transmission, flow rate, and opening pressure. There might also be differences in the connector design.
- Why is the vehicle emitting white smoke?
I hope my word choice is better now.
Sure, here's the translation:
"Thank you in advance."
Translated on 02-11-2026, 14:01.
27-07-2009, 22:08 Subject: Fuel Injection Error 00550: Troubleshooting Guide |
Kolbenring wrote: | | - VFP, could this be the cause? |
No.
Kolbenring wrote: | | Or is this just a backup unit? |
Yes.
Regarding the pump part number: Simply order a new one for YOUR car, and you'll get the correct one. There's no need to buy a used one. These things are simply too prone to failure. Why would someone remove a fully functional pump and sell it??? Of course, there are a few rare reasons, but then you would need to know exactly which pump it is.
How and when did the problem actually occur? Did it happen suddenly, or gradually? MfG. Michael
Translated on 02-11-2026, 14:05.
Profile PM Garage |
Kolbenring Blaumann
28-07-2009, 12:30 Subject: Fuel Injection Error 00550: Troubleshooting Guide |
Well, since I haven't been driving the vehicle myself for quite some time, I have to rely on the subjective assessment of the driver, which is my wife.
Background:
The vehicle now has 230,000 km on the odometer, and the engine has approximately 80,000 km. For the sake of completeness, I should mention that my wife switched from diesel to regular gasoline at 165,000 km, which was the reason for the replacement of the variable valve timing (VVT) unit.
Well, from April to November of last year, I drove the vehicle approximately 50,000 kilometers without encountering any issues. Since then, my wife has been using it, also driving around 700 kilometers per week.
At some point, she complained about a loss of power (the error memory didn't register anything like that, but that doesn't necessarily mean anything). I checked it and it was correct; there was a "dip" in power between 2200 and 2700 rpm, especially when accelerating, particularly uphill. Eventually, it started to smell like oil, and the blue smoke increased. There was oil in the expansion tank from the crankshaft breather. I think the filter is the culprit here. The expansion tank is probably not fresh either. Additionally, there are other errors in the memory, such as "overboost" and "pressure regulation limit." This error has been present since the beginning; okay, it's also because a piston skirt has been damaged. These issues, along with others, led to the decision for a major overhaul. The expansion tank and filter for the crankshaft breather are ready, as are the timing belt and water pump. Since she's due for a TÜV inspection, I wanted to take care of this first. The engine ran cleanly; I revved it up to 4500 rpm while stationary, and everything seemed fine. I drove off, and then it was time to go home. To answer your question, there are signs of trouble, but for me, it seems to be happening out of the blue. I'd be interested in your opinion.The VFP (Variable Flow Pump) is giving me trouble; I'm just having problems with it. What's the warranty on these components? Is it one year or more? Besides buying from a dealer, where else can I purchase such a pump?
Translated on 02-11-2026, 14:08.
